DTC Trouble - Mustang Evolution
Old 09-27-2011, 01:27 PM   #1
MustangMafia97's Avatar
Send a message via AIM to MustangMafia97
DTC Trouble
Hello, I have previously installed Pypes O/R X pipe on my 97 Mustang, about 700 miles after I stalled the pipe i have received the following codes.
P0131 O2 Sensor Low Voltage Bank 1 Sensor 1
P0420 Catalyst System Efficiency Below Threshold Bank 1
P1131 Lack of HO2S1 Switches Bank 1 Sensor 1
The odd thing is I have previously had a Bassani Hi-flow Catted X-pipe, I have only received codes on Bank 1, none for Bank 2 however.
I'm not sure what else to try to "fix" the problem, Thanks in advance.
Nothing but Ford...Nothing but American Muscle
MustangMafia97 is offline   Reply With Quote
Old 09-27-2011, 02:29 PM   #2
Camo1967Mustang's Avatar
Re: DTC Trouble
Do you have an exhaust leak?
My car threw a P0420 and thats what caused it
Idk about the other codes
Adrian
2001 Mustang
--AM CAI, BBK Headers, Dual exhaust, Billet grille, hood and side scoops, Sequential tail lights,
AM Headlight covers, Fog lights, Chin spoiler, H&R Lowering Springs, KYB Shocks and Struts
January 2012 StangAlley ROTM
Camo1967Mustang is offline   Reply With Quote
Old 09-27-2011, 03:53 PM   #3
ksrumbel's Avatar
You need MIL eliminators or a tuner. You don't have cats so your car will throw a code. MIL eliminators are about $70 at cj pony parts.
ksrumbel is offline   Reply With Quote
Old 09-28-2011, 03:59 PM   #4
Re: DTC Trouble
I was thinking I would need MIL eliminators at some point, just went so long without throwing any codes.
Old 09-28-2011, 07:27 PM   #5
RedGT04's Avatar
I just got my cats taken out and check engine light came on I got a pair of mil eliminators hookedthem up and problem solved ... U probably have to get ur check engine light reset otherwise it will stay on the whole time
RedGT04 is offline   Reply With Quote
Old 10-02-2011, 12:13 AM   #6
94 Mustang GT's Avatar
If he were to fix the issue and not reset the light after 3 drive cycles the obd system would turn it off on it's own.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 10-02-2011, 08:00 AM   #7
RedGT04's Avatar
Sounds good
Old 10-02-2011, 02:33 PM   #8
Re: DTC Trouble
in order to fix the issue, I would have to install stock mid pipe on it, and i'm not doing that. That is such a pain to uninstall let alone install.
Old 10-02-2011, 07:36 PM   #9
Mustang_gt_03's Avatar
Region: New Mexico
The cheapest way to solve your problem is to take out the check engine lightbulb if it really bothers you, that's what I did. I'm pretty sure you'll be able to tell if your car is acting up without the light anyways.
Mustang_gt_03 is offline   Reply With Quote
Old 10-02-2011, 07:42 PM   #10
RedGT04's Avatar
Now that's a solution for the CEL lol
Old 10-02-2011, 07:46 PM   #11
Region: New Mexico
^^lol^^
Old 10-02-2011, 08:31 PM   #12
RedGT04's Avatar
Mine came on when I took my cats off too even tho I put a mil eliminator
A/C trouble Exodus1021 2011-2014 Mustang GT 2 10-12-2011 03:09 PM
Rear end trouble Dgerow12 Pre-2005 V6 Mustang 15 09-08-2011 03:59 AM
tranny trouble? 5.slow 1979-1995 Mustang GT 32 08-28-2011 07:40 PM
Display pic trouble shazzsk89 General Car Discussion 1 08-20-2011 10:04 AM
Engine trouble! 99ford 2005-2010 V6 Mustang 7 08-02-2011 11:52 PM
02:34 AM
