my car wont accelerate it starts to shake - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Closed Thread
Old 09-28-2011, 05:56 PM   #1
02gtmustang is unknown around these parts
02 GT every time I accelerate wont pick up it starts to shake I already change the spark plugs and coils I'm thinking its the fuel filter or gas regulator
02gtmustang is offline
Old 09-28-2011, 06:08 PM   #2
nickysixx's Avatar
nickysixx is unknown around these parts
Wires?
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT
2002 Jeep Grand Cherokee Laredo
nickysixx is offline
Old 09-28-2011, 06:42 PM   #3
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
Originally Posted by nickysixx
Wires?
+1, sounds like they are grounding out.
93slowstang is offline
Old 09-28-2011, 07:13 PM   #4
PonyBoyV6's Avatar
PonyBoyV6 is unknown around these parts
Had the same problem with my car, wouldn't accelerate passed 40. Turned out a couple wires shorted out. Changed them out and the car ran great.
PonyBoyV6 is offline
Old 09-28-2011, 07:27 PM   #5
Mine keeps accelerating but it shakes..when ever I its on park if u go to the mufflers it sounds like its misfirein
Old 09-28-2011, 08:43 PM   #6
Moderator
Sounds like the wires may be grounding out if it's missing, or you don't have a good connection.
Old 09-28-2011, 10:20 PM   #7
nickysixx's Avatar
Yep. Went through a whole tune up with my mustangs. Wires are a major problem once they short.
1996 Mustang GT
Old 09-28-2011, 10:37 PM   #8
Moderator
Oh real easy way to check for grounding wires is to go to a dark spot at night and crank the car. Look under the hood and if it looks like "Christmas lights" then your wires are bad. You may have to rev the motor to be able to see them arching out if they are bad.
Old 09-28-2011, 11:04 PM   #9
nickysixx's Avatar
+1
1996 Mustang GT
Old 09-29-2011, 07:41 AM   #10
onesickstang01's Avatar
onesickstang01 is unknown around these parts
If the car is an 02 gt then there are no wires. They are coil on plug
---------- Post added at 01:41 PM ---------- Previous post was at 01:37 PM ----------
Check the fuel pressure. Ive seen many times a fuel pump do this. Make sure you are getting correct voltage to the pump as well. Ive seen where the relay goes in and out and wont create efficient fuel pressure. Our cars have the relay in the ccrm which is a common failure as well as the fuel pump driver module which isnt as common to fail. You always want to chamge the fuel filter every so often. If not it can cause premature pump failure
onesickstang01 is offline
Old 09-29-2011, 07:43 AM   #11
t0t4lbl4ck0ut's Avatar
t0t4lbl4ck0ut is unknown around these parts
Check your o2 sensors. Mine was doing similar stuff and I had a bad o2 sensor
t0t4lbl4ck0ut is offline
Old 09-29-2011, 01:23 PM   #12
Thanks for the answers!! And another thing it just started liking antifreeze but don't know were is coming from from the back of the engine were the engine and transmission connect I'm think its one of the seals ya think its ganna be expensive or I can just put an radiator sealant
Old 09-29-2011, 01:26 PM   #13
Moderator
If it's coming from the firewall it's your heater core.
Old 09-29-2011, 01:33 PM   #14
Oh ok thanks ima check on that
Old 09-29-2011, 02:40 PM   #15
If its leaking coolant thrn its probably dripping down into the coils and makin it misfire.
Old 09-29-2011, 02:52 PM   #16
But its leaking thru the bottom right in the middle of the car were the engine and trans connect none of the lines are leaki
Old 09-29-2011, 07:09 PM   #17
That usually happens when it drips down under the intake and sits in the valley. You need to find where the leak is. White crusty residue will point it out. Pull the coils out and see if there is coolant or the crusty stuff.
Old 09-29-2011, 09:11 PM   #18
Oh ok appreciate that ima look into that
Closed Thread
fast car andyr421 1996-2004 Mustang GT 28 11-13-2011 05:08 PM
First time claying my car...wow illestdomer2005 2010-2014 V6 Mustang 13 09-28-2011 03:00 PM
97 GT Smelling gas fumes in car Sharky97 1996-2004 Mustang GT 2 09-20-2011 02:54 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
What mods can get 350+hp? Johnstonb93 2005-2009 V6 Mustang 50 08-18-2011 05:39 PM
08:56 AM
