Major Engine Trouble With Spark Plug Coils - Mustang Evolution
Old 09-29-2011, 03:51 AM   #1
504 Stang Rida's Avatar
It all started 3 days ago when I was heading to work my engine started to missfire real bad. So when I got off work I checked all of my coils & plugs. I found out 1 of my plugs wasn't screwed in properly and it cracked my 6 spark plug coil. So I installed the plug back in properly and replaced the coil. Soon as I replaced the coil with a newer 1 and started my engine the same coil that was replaced and the coil next to it coil 5 blew and coil 6 caught on fire. Luckly I was in my drive way when this happen so I quickly put the fire out. What could be the reason my coil keep blowing like that and how to fix the problem?
504 Stang Rida is offline   Reply With Quote
Old 09-29-2011, 08:06 AM   #2
Re: Major Engine Trouble With Spark Plug Coils
It sounds like you may have a short circuit somewhere or possibly a failed resistor that is allowing too much voltage to enter the coil.
Also check and verify that your grounds are in cood condition and making good contact, especially the engine grounds.
Old 09-29-2011, 09:45 AM   #3
Yea I'm going to take everything apart this weekend because I need to now replace my ecu wire harness because it melted with the small fire tha happened due to the coil blowing
Old 09-29-2011, 09:49 AM   #4
are these OEM COP's?
Old 09-29-2011, 02:38 PM   #5
No there acel plugs
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
Spark plug and coil pack sudgestions? p1blake04 1996-2004 Mustang GT 11 08-30-2011 05:18 PM
How Do I Clean Out My Holes? ...spark plug holes? Nel86 General Car Discussion 8 08-06-2011 03:55 PM
Spark plug blown out of head. 1bad2v 1996-2004 Mustang GT 17 07-03-2011 08:29 PM
12:56 AM
