trans problems 1st to 2nd automatic - Mustang Evolution
Old 10-03-2007, 07:39 PM   #1
Thumbs down trans problems 1st to 2nd automatic
Hi all, The car sat for about 3 years in a garage. I finally got to rebuilding the motor,got it running great untill I went to test drive it.It took forever to shift from 1st to 2nd .When I take off from a dead stop the engine revs up to 3k rpm and it finally starts to move.when it shifts in to 2nd it shifts normally thru the rest of the gears and down shifts thru all of the gears as well.I changed the trans fluid and filter using mobil one mercon v trans.fluid. Filled to the proper level.While the car sat for 3 years it was low in trans.fluid. Also the transmission was gone thru and shift kit installed before the engine died Does anyone have any ideas of what can be wrong.can anyone help!!!!
96 cobra vert is offline   Reply With Quote
Old 10-03-2007, 07:50 PM   #2
Re: trans problems 1st to 2nd automatic
Sounds like your torque converter is going out...or gone.
Old 10-03-2007, 08:09 PM   #3
Check your Throttle Positioning Sensor.
Old 10-03-2007, 08:47 PM   #4
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Sounds more to me like it might be a shift solenoid, but I believe that a solenoid usually controls 2 gears...
After it gets done revving up, does it actually engage in first or does it go straight to second?
DarkShadow is offline   Reply With Quote
Old 10-03-2007, 10:20 PM   #5
The car will not move untill it reaches the 3000 rpm range at that point it will engage in first.
Old 10-03-2007, 10:22 PM   #6
I also get a whistle sound or maybe a vac. leak sound when I shift it into drive or any of the forward gears but not in reverse.
Old 10-03-2007, 10:23 PM   #7
what would the tps have to do with it?
Old 10-03-2007, 10:37 PM   #8
It controls shift points. If it's bad or not aligned correctly it will throw off your shifts and cause it to not shift unless you lift off the gas. It happened to me.
Old 10-04-2007, 03:04 AM   #9
hey thanks a lot I would never of guest that!
Old 10-04-2007, 01:33 PM   #10
I checked out the T.P.S it seems to be in good working order.Is there any thing else I should check out?
Old 10-18-2007, 06:21 PM   #11
anymore ideas someone has got to know something.
Old 10-18-2007, 06:23 PM   #12
If its not the TPS then I'm going to side with DarkShadow
Old 10-18-2007, 09:34 PM   #13
DarkShadow's Avatar
Just throwing more ideas out:
Do you know if the shift kit was installed 100% correctly?
How long did it remain in running condition after the kit was installed?
Do you remember it doing anything funny before the motor problems?
All fluids if left to sit over time lose their ability to function like they should. They begin to collect and cause buildup. You might need to have the tranny flushed, instead of just new fluid.
If it's not a solenoid or TPS, it's going to be something internal. A stuck or sluggish valve etc. If you've seen the inside of an auto tranny it's hard to believe they work as well as they do. It's just sounds to me like it's taking the transmission an extrememly long period of time to build up the needed pressure to shift, or it could even be a failing clutch pack.
My personal opinion, I think it's going to be a band, clutch pack, or something else mechanical relating to that gear only being that the rest of the gears seem to work fine...assuming the shift kit was installed correctly.
Old 10-18-2007, 10:00 PM   #14
DarkShadow's Avatar
Doing a little Googling and I found that there were a few problems with the accumulator springs and piston that seem like they could relate to your problem. These problems were remedied in `98. When failing they don't allow enough pressure. I also read a few things on the solenoid causing similar problems so you might want not want to rule that out.
Old 10-19-2007, 01:41 PM   #15
Herbstang's Avatar
check the adjustment on the tv cable also it could be a sticking governor,
or sticking valves in the valve body. Might want to try some trans additive to free them up you want something that will flush the passages. then change fluid.
2006 Clutch - very minor chatter from 1st - 2nd RedFire2006 2005-2010 Mustang GT 3 10-07-2009 09:19 PM
Need Automatic Trans info twistid1 1996-2004 Mustang GT 1 06-08-2009 05:05 PM
Belt slips when shifting from 1st-2nd??? mohrnormal 1996-2004 Mustang GT 5 04-12-2006 02:45 PM
2006 V6 Manual Trans - Bucks in 1st Gear in AM lovcom Pre-2005 V6 Mustang 9 11-20-2005 09:08 AM
spring problems, 1st post fb305 Pre-2005 V6 Mustang 28 01-04-2004 10:43 PM
11:14 AM
