Swap? - Mustang Evolution
Old 10-02-2011, 08:56 AM   #1
Brett Greene's Avatar
Swap?
I have a friend who had bought a 95 mustang with a few bolts ons.
He found a supercharged 96 GT and was wondering if you can swap out the mods.
Aluminum Drive Shaft
CC plates
Lowering Springs
Maximum Motor Sport Lower Control
Tokio Shocks
70 mm Throttle body
---------- Post added at 08:56 AM ---------- Previous post was at 08:54 AM ----------
Oh also BBK long tubes
Off road x pipe
Flow master 40s
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 10-02-2011, 10:40 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Swap?
sooo the '96 is a 4.6 and the '95 is a 5.0? if the motors are different. all the parts will swap over minus the blower, the throttle body, the long tube headers, and the blower.
everything else u listed will swap
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-02-2011, 10:48 AM   #3
The 5.0 has a blown motor. He is gunna buy the 96. Just wants to know if the suspension and stuff with work. I figured after the exhaust system wouldn't work.
Old 10-02-2011, 11:05 AM   #4
Titus Wadicus
svtlx's Avatar
Re: Swap?
yup it will all fit. i transplanted everything from my 92 coupe to my 96. rear uca/lca, sway bar, full exhaust front to back.
besides the headers cause of the motor obviously, but the mid pipe should swap and the muffler section is a definate
just so u know, u can swap everything from a fox all the way up to '04 with very lil modification.
the main chassis difference is that ford moved the motor back 1 inch for weight transfer and handeling with the 94-04. doesnt seem like alot, but it is.
long story short.. your buddy is in good shape
Old 10-02-2011, 11:08 AM   #5
Right on man. I don't know much about the 4.6. Just wanted to make sure
Engine swap 96 stang 1996-2004 Mustang GT 8 09-19-2011 06:56 AM
Pi engine swap Kurlywhiteboy 1996-2004 Mustang GT 0 08-14-2011 09:48 PM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
2000 3.8 ยป 4.6 swap mustang newb sethhawk1 Pre-2005 V6 Mustang 14 07-28-2011 10:41 PM
Engine swap, here we go Mustanglife General Mustang Discussion 65 07-05-2011 08:07 PM
02:57 PM
