Engine trouble - Mustang Evolution
Old 10-11-2011, 01:27 PM   #1
Berbantor's Avatar
Engine trouble
So my car spotters and times wen I'm cruising. Doesn't do it all the time maybe for a min then goes Away for a couple mins then does or again. And no cel
2001 gt, 5speed. 70mm throttle body with stackracing plenum. bbk intake, 4.10 eaton posi, short shifter, o/r side exhuast.
Berbantor is offline   Reply With Quote
Old 10-12-2011, 10:47 AM   #2
Re: Engine trouble
Sounds like a spark plug or coil boot problem. Does it seem to do it when it is under load? How long has it been since the plugs were changed.
2001 GT AUTO, MAgnaflow Cat back, 70mm TB, K&N FIPK, C-springs, 275/40/17 all around
jjandascog is offline   Reply With Quote
Old 10-12-2011, 01:12 PM   #3
Berbantor's Avatar
Re: Engine trouble
well i just bought the car in feb. i just changed the fuel filter and it was clogged bad, but still does it. and no im not sure when the plugs were changed out. how would i check for a bad cop.
Old 10-15-2011, 09:48 AM   #4
fericyde's Avatar
Re: Engine trouble
My 2000 GT needs fuel injector cleaner every springtime -- usually sits a lot over the winter and acts quite like you're describing here. It might also be a damaged fuel pump (if you drive the car a lot with a bad filter this can happen). I'm not an expert on how to check for this though -- my guess is that you need something to test the fuel pressure somehow.
fericyde is offline   Reply With Quote
Old 10-15-2011, 01:29 PM   #5
t0t4lbl4ck0ut's Avatar
Mine did similar things and had a bad o2 sensor
t0t4lbl4ck0ut is offline   Reply With Quote
Old 10-15-2011, 07:16 PM   #6
Mustang_gt_03's Avatar
Region: New Mexico
I have a Roush one and I love it. Besides it was only $200.
Mustang_gt_03 is offline   Reply With Quote
Old 10-15-2011, 11:19 PM   #7
Berbantor's Avatar
Yea mine doesnt do it all the time idk wat to check nxt
Old 10-16-2011, 12:08 AM   #8
bobsurvives's Avatar
Just take the car to a local mechanic have him find out what the problem is and fix or replace whatever you need to yourself... A mechanic here in LA charged me $20 hooking up my car to his code reader then taking it apart a little finding out what caused the problem... Which was a cracked intake manifold flooding the cylinder and causing a misfire.
bobsurvives is offline   Reply With Quote
Old 10-16-2011, 10:56 PM   #9
Berbantor's Avatar
I don't have any codes and everywhere close to me in brookpark ohio wants 100 bucks to diag.
---------- Post added at 10:56 PM ---------- Previous post was at 10:54 PM ----------
Oh and yes it does it under load but not all the time. Sometimes it sounds Like a paintball gun running out of co2. Lol. That's the best way to discribe it.
Old 10-17-2011, 12:18 AM   #10
That's as much as the dealership would charge here in California
Old 10-24-2011, 03:23 PM   #11
DaBluedude's Avatar
Re: Engine trouble
Hey sounds to me like you need to get the whole thing tuned properly, the stock tuning wont work properly with the TB/plenum and other mods your running. That and replace your O2 sensors.
Old 10-24-2011, 10:45 PM   #12
Berbantor's Avatar
Well I have it tuned. But y would I replace the u2 sensors. Plus fence I went up to 93 octane. Would it mess up my spark plugs. Cuz wen I looked at them they had grey on them.
Old 10-24-2011, 11:02 PM   #13
Re: Engine trouble
I would try regular pump gas.
Gtparedes is offline   Reply With Quote
Old 10-24-2011, 11:25 PM   #14
Berbantor's Avatar
So 87 octane. Cuz we have I think 87. 89. 91. And 93 pump gas.
Old 10-25-2011, 08:12 AM   #15
Re: Engine trouble
Yeah out here we only have 87 89 and 91.
Old 10-25-2011, 08:56 AM   #16
Berbantor's Avatar
Really so maybe just 91 then.
Old 10-25-2011, 09:47 AM   #17
There is nothing wrong with running different gas and the higher octane the better. I'd run what your cars tuned for though.
Major Engine Trouble With Spark Plug Coils 504 Stang Rida 1996-2004 Mustang GT 4 09-29-2011 02:38 PM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
having trouble help check engine light keeps coming on for the same code mustangsally696 General Car Discussion 2 08-18-2011 07:02 AM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
Engine trouble! 99ford 2005-2010 V6 Mustang 7 08-02-2011 11:52 PM
02:05 PM
