Auto to Manual. What will work? - Mustang Evolution
Old 10-13-2011, 03:06 PM   #1
MustangGT02's Avatar
I have a 2002 Mustang GT and im wanting to convert it to a 5-speed. Will a T-5 or T45 work? It seem like the newer transmissions are more and I cant find any around here.
Thanks for the help.
MustangGT02 is offline   Reply With Quote
Old 10-13-2011, 05:05 PM   #2
93slowstang's Avatar
T-45 is the one out of those two to use.
Old 10-13-2011, 05:22 PM   #3
Re: Auto to Manual. What will work?
t-45, t3650 or t-56 for your year. fyi, if you plan on hard shifting and upgrading to hard clutch you may start crank walk (end play). many automatic vehicles from factory don't use many thrust bearings on the crankshafts outer mains, since in an auto there isn't any hard forward/backward pressure on the crankshaft when auto shifting vs manual shifting. so, you install a manual transmission you will be creating more force when shifting than a smooth automatic transmission. not to scare you, but wanted you to know. you will be ok for daily driving, but over time the the bearings will wear.
jk_aktion is offline   Reply With Quote
Old 10-13-2011, 07:00 PM   #4
I would not count my auto as a smooth shifting transmission. If I put it in 1 and then put it into 2 it will break the tires loose.
Thanks for the info though and it will by my daily driver and im not going crazy on the car.
Old 10-13-2011, 07:40 PM   #5
it is still smooth compared to manual with a clutch that actuates forward and backwards against the flywheel wich is connected to the crank wich inturn will put pressure back and forth on the crank as you shift, all that auto shifting from your current trans doesn't have the back and forth motion as a manual. that force you feel in your auto is the torque from the motor. hope this is easier to understand, more knowledge is better. i'm not busting, just giving you some info.
Old 10-13-2011, 08:48 PM   #6
Ohh no im not mad at this the more I learn the better. So if im doing around town driving with the occasional flooring of the car I should be fine?
Also after looking at priceing it will have to wait tell next summer for me to do this so Im getting the info now so it will be easier later.
Old 10-13-2011, 10:41 PM   #7
yea you're gonna be fine, but over time you will create crank walk, and at high rpms it will warp the crank and rods because of the play it will have and then eventually fail. just like everything else that has moving parts, they wear and fail, that's just how it is.
Old 10-13-2011, 11:44 PM   #8
upton7's Avatar
Why are you doing this?
Old 10-14-2011, 05:56 AM   #9
KATO's Avatar
My opinion is: You should not do this. Change Gears, Converters, quick shifters, whatever, but don't change whole thing. I drive an Automatic, but I have owned a stick in the past. I think you will be asking for more, and more problems down the road.
Old 10-14-2011, 06:10 AM   #10
deadsp0t's Avatar
+1
That's unimpressive
Injectors not pulsing? Otlaw80 1979-1995 Mustang GT 21 07-27-2014 03:12 PM
Manual T45 Problems? BrKu789 1996-2004 Mustang GT 2 10-06-2011 06:26 PM
Auto to manual Driftfiend Pre-2005 V6 Mustang 1 09-07-2011 06:34 PM
Auto to Manual swap? BrKu789 1996-2004 Mustang GT 9 07-17-2011 09:17 PM
Auto to manual swap Jamesgt08 1996-2004 Mustang GT 6 06-25-2011 01:45 PM
08:20 PM
