Figured out the problem.. - Mustang Evolution
Old 10-15-2011, 08:16 AM   #1
ColeJohnson's Avatar
Cylinder three was leaned out and apparently had a slight knock for some time, but eventually got loose and hit the tip of the sparkplug and broke it.
Verdict... Cylinder three is blown. I need a new engine.
Any suggestions on a replacement? I'm a college student with no money, so I'ma have to save up. And I am NOT putting a junkyard/used motor into it.
2016 Comp Orange GT (current)
Old 10-15-2011, 09:52 AM   #2
what year stang?
Sb98gt is offline   Reply With Quote
Old 10-15-2011, 09:56 AM   #3
Re: Figured out the problem..
2002.
We're running compression test on the cylinders to see if we can salvage it or not..
Old 10-15-2011, 10:58 AM   #4
oh ok yea i had same problem also i did motor rebuild an new heads
Old 10-15-2011, 11:11 AM   #5
Well, that just sux!
Sorry to hear of your bad luck.
Is the engine block damaged?
If not to bad maybe it can be bored or sleeved and a new piston/rings installed.
Old 10-15-2011, 11:29 AM   #6
mystang50's Avatar
cuz those burnoutz!! lol but thats horrible news man im srry
Old 10-15-2011, 01:21 PM   #7
t0t4lbl4ck0ut's Avatar
Yea I was gonna say the same thing. Along as the block isn't tore to shreds there's ahold chance you can just have it bored and get some new pistons and rings and be set
t0t4lbl4ck0ut is offline   Reply With Quote
Old 10-15-2011, 01:22 PM   #8
Haha, I honestly did one burn out only. Never did one since then.
---------- Post added at 02:22 PM ---------- Previous post was at 02:21 PM ----------
Won't that still be like $2k+?
Old 10-15-2011, 01:24 PM   #9
I know that sounds like a lot but it's a lot cheaper then a new motor. It's probably cheaper then just a block even
---------- Post added at 07:24 PM ---------- Previous post was at 07:22 PM ----------
No way man a new set of pistons like only cost ya 500 max and that's with forged pistons which is more then you NEED but might want down the road. Less then 700 is my guess on total cost without labor
Old 10-15-2011, 04:17 PM   #10
My friend ran a compression test on it before we started replacing everything and he found them all at 175 so he just replaced all the plugs and reset the cam and fixed a small vacuum leak and bam!! I'm driving smooth as butter!
Old 10-16-2011, 02:08 PM   #11
Phew! I bet that's a huge relief.
Old 10-16-2011, 02:32 PM   #12
deadsp0t's Avatar
Cool deal, glad to hear it wasn't serious! Rebuilds=downtime
That's unimpressive
98 Mustang V6 Starter Problem creilly702 Pre-2005 V6 Mustang 5 08-31-2011 07:45 PM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
Drivers side window problem bullitt1075 1996-2004 Mustang GT 3 07-20-2011 10:47 AM
Cooling fan and AC problem, please help 95GTS 1979-1995 Mustang GT 4 07-08-2011 08:24 PM
05:22 AM
