Can I tell what mods I have - Mustang Evolution
Old 10-15-2011, 04:48 PM   #1
86 muscle's Avatar
And if so how, I can see shorties, x pipe cat back and cai but is there a way to tell if it has a programer or cams it has a semi lopiy idle, it and gets fairly bad gas mileage...is there any way to tell what i've got done?
86 muscle is offline   Reply With Quote
Old 10-15-2011, 04:54 PM   #2
93slowstang's Avatar
If you post a video of it idling we may be able to help determine if you have a cam. You can pull your valve covers to see if the valvetrain has been upgraded. You would have to pull your computer out from behind the pass side kick panel to see if a chip is attached.
---------- Post added at 05:54 PM ---------- Previous post was at 05:54 PM ----------
Oh an sometimes a vacuum leak will cause a lopey idle and bad gas mileage.
Old 10-15-2011, 04:56 PM   #3
86 muscle's Avatar
Best way to tell if I have a vacuum leak? Cause the thing runs like a bat out of hell
Old 10-15-2011, 05:02 PM   #4
Just follow all the vacuum lines if you can't hear any. If you can't find any you more than likely have a cam.
Old 10-16-2011, 02:35 PM   #5
86 muscle's Avatar
Well I uploaded a video on youtube but I can't post on here through my phone, it's under myfine86. That's my channel name its titled 2000 gt Mustang
Old 10-16-2011, 03:14 PM   #6
Sounds like the stock idle to me.
---------- Post added at 04:14 PM ---------- Previous post was at 04:11 PM ----------
Here's the link for your vid
http://youtu.be/qI4N_ebts2U
Old 10-16-2011, 03:20 PM   #7
03GT88's Avatar
Yep sounds good to me. No cams.
03GT88 is offline   Reply With Quote
Old 10-16-2011, 03:28 PM   #8
86 muscle's Avatar
Okay so why does it want to die when the A/C is on, I hear no vacuum leaks
Old 10-16-2011, 09:59 PM   #9
03GT88's Avatar
Didn't u ask that on another thread? Anyway it could be your battery or alternator not putting out enough.
Old 10-17-2011, 05:17 AM   #10
86 muscle's Avatar
I did but I had no replies.
Old 10-17-2011, 05:21 AM   #11
03GT88's Avatar
Well get your battery and alternator checked
Old 10-21-2011, 12:05 PM   #12
Re: Can I tell what mods I have
what year mustang is it?
kenco1 is offline   Reply With Quote
Old 10-21-2011, 05:09 PM   #13
86 muscle's Avatar
2000
Old 10-21-2011, 06:04 PM   #14
I have a 2000 gt and I was getting that lobe or rocking turned out to eventually produced a check engine light as cylinder 3 miss fire I replaced the cop s and it went away does any car part stores buy you let you use the free obd 11 scanners if so then there is a data log function and you can check your real time lambse1 and lambse2 they should hover right around 1 if they go well below 1 say .765 or below then it is a rich burn meaning coil spark is weak
2011-2012 5.0 Mods; list them avengnd 2011-2014 Mustang GT 34 09-28-2011 12:07 PM
Mods for a gt500 SALEEN General Mustang Discussion 9 09-18-2011 06:05 PM
Mods for a mustang saleen SALEEN General Mustang Discussion 0 09-17-2011 05:39 PM
Mods? afree05 2005-2010 V6 Mustang 15 07-04-2011 10:50 PM
97' v-6 mods dandan Pre-2005 V6 Mustang 2 06-26-2011 09:51 AM
12:12 PM
