02 gt need help - Mustang Evolution
Old 10-19-2011, 11:11 PM   #1
Nate98stang's Avatar
02 gt need help
My car misses out and docent really have power un plugged all my coils one at a time all the cylinders are ok but I have a blown manifold gasket and an exhaust leak could the miss and power loss be due to the leaks and maybe clogged cats?
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 10-20-2011, 02:13 AM   #2
Mustang_gt_03's Avatar
Region: New Mexico
Is it a blown intake manifold gasket or exhaust manifold gasket?
Mustang_gt_03 is offline   Reply With Quote
Old 10-20-2011, 06:27 AM   #3
jjsg09's Avatar
If your intake gasket is blown your plastic intake maybe cracked also. But yes either of those issues will give u a hiccup or misfire. Your O2 sensors might be reading wrong and your getting the wrong fuel to air mixture and the intake might be adding to much air to cylinders
Old 10-20-2011, 09:37 AM   #4
Yea it's my exhaust manifold gasket that's blown and I can hear a leak back by my driver door
Old 10-20-2011, 05:05 PM   #5
Region: New Mexico
Then idk cuz if the intake manifold gasket was blown then antifreeze or water would be leaking into the spark plugs causing it to bog down & misfire (happened to me).
Old 10-20-2011, 06:04 PM   #6
I have an antifreeze leak but it's at the thermostat housing not causing any harm at the moment
Old 10-20-2011, 08:27 PM   #7
onesickstang01's Avatar
But the coolant can run down into the spark plug well and short it out. Very common
onesickstang01 is offline   Reply With Quote
Old 10-20-2011, 09:01 PM   #8
Even from the thermostat ?
Old 10-21-2011, 02:36 AM   #9
Region: New Mexico
Maybe, you might wanna fix that leak first just to make sure. The thermostat housing is like $18 at AutoZone.
Old 10-21-2011, 08:13 AM   #10
Ok thanks man I appreciate it gave 4100 forth car few days ago trying to fix it b4 winter
---------- Post added at 08:13 AM ---------- Previous post was at 07:46 AM ----------
Oh and if I replace the housing and gasket then try to replace my coils how can I make sure all the antifreeze is out of the spot for the coil
Old 10-21-2011, 11:25 AM   #11
Region: New Mexico
It'll dry up from the same heat of the block & spark plug in a days worth of driving as long as it doesn't keep on leaking in there.
Old 10-21-2011, 12:24 PM   #12
Well me and a buddy took out the coils and plugs soaked in antifreeze it's def my intake gasket gonna have it fixed sometime this week I hope
Old 10-21-2011, 12:54 PM   #13
bobsurvives's Avatar
Happened to me too, upgraded to aluminum manifold.
bobsurvives is offline   Reply With Quote
Old 10-21-2011, 01:08 PM   #14
Well I have a guy fixing the gasket think it will b ok or just blow again?
Old 10-21-2011, 01:38 PM   #15
Region: New Mexico
It should be fine the gasket should last you around 10 or so years if done right.
Old 10-21-2011, 01:52 PM   #16
Alright just ordered a bbk o/r x pipe to get the cats off the car should b here by the time I get the intake fixed then it should hopefully b running and sounding a ton better appreciate all the help guys
Old 10-21-2011, 04:10 PM   #17
Oh and I'm pretty sure I have a 99-00 engine in my car it was a rebuilt title and has marking on the heads and the thermostat housing I think matches up with a 99 not an 02
ID:	33390   Click image for larger version
Old 10-21-2011, 06:00 PM   #18
Post a pic of the water pump pulley and count the valve cover bolts and i can tell you if its a 01+ or pre 01 and if its romeo or windsor
Old 10-23-2011, 11:40 AM   #19
Just dropped my car off to get the intake fixed so I'm pretty sure my throw out barring is out or going out can that hurt anything or just makes the noise?
Old 10-30-2011, 11:47 PM   #20
My whole intake ended up being cracked so I'm now gonna b out about 600 for that fix if I need coils replaced due to the antifreeze leaking into them 380 more and my throw out barring going out my mechanic told me I should buy a whole new clutch kit so another 300-400 there this car is a money pit already lol but guess that's part of owning a car
Old 10-31-2011, 08:03 AM   #21
Eturner's Avatar
It's all part of owning it and modding it!... But the molding part is fun!!!!
Old 10-31-2011, 08:37 AM   #22
Yea that's right got a bbk x pipe sitting in my room just waiting for the car lol
Selling the GT killer The Darkside Mustangs for Sale and Wanted 24 10-18-2011 09:36 PM
Will Stock 1998 GT H-Pipe Fit My 2003 GT? Brent 1996-2004 Mustang GT 5 10-12-2011 08:44 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
03:39 PM
