Pullies worth it or not - Mustang Evolution
Old 10-20-2011, 02:04 PM   #1
86 muscle's Avatar
I can get some steeda under drive pullies new in box for around 100 bucks but are they worth it?
86 muscle is offline   Reply With Quote
Old 10-20-2011, 02:38 PM   #2
Filibuster
If its three pulleys then YES!!!...buy now!!...the steeda set runs around $200 new...
XXSTEVEO66 is offline   Reply With Quote
Old 10-20-2011, 02:54 PM   #3
Re: Pullies worth it or not
7rwhp or so~ not a ton but not bad either.
Old 10-20-2011, 03:11 PM   #4
Filibuster
I also noticed a little better throttle response...but at the same time I deleted the a/c as well..
Old 10-20-2011, 04:04 PM   #5
86 muscle's Avatar
I have them done to my 86 and I like them but its kinda hard on the alternator
Old 10-20-2011, 04:11 PM   #6
Filibuster
Yeah thats true if your running a/c,radio ect...you can always keep the stock pulley on the alt if needed..good thing on the fox's they just unbolt no puller needed..so you can change them quickly!..
Old 10-20-2011, 04:20 PM   #7
It's not me, it's you.
primer2tone's Avatar
I'll bet your throttle was mostly from bypassing the a/c compressor.
Old 10-20-2011, 04:41 PM   #8
Filibuster
Yeah I couldn't tell you otherwise because I did it at the same time!..
Old 10-24-2011, 08:05 AM   #9
Fast04's Avatar
They are worth every penny. Don't change the alt pulley though.
Fast04 is offline   Reply With Quote
Old 10-24-2011, 08:17 AM   #10
jjsg09's Avatar
I could feel a difference in my throttle. I changed the alt pulley too works fine and looks better under the hood. If you have an impact it will take the bolt right off and any shop or parts store will do it for you or they should. Just make sure you read the directions carefully and not over torque down the crank bolt. Steeda gives you one that is just a starter bolt for the new ones. Do Not Torque on this bolt
Old 10-24-2011, 08:51 AM   #11
stampde's Avatar
did mine in the Mach minus alt pulley ,got 4.5 rwhp
2011 GT Auto
19" Brembo Wheels, What are they worth? Kystang615 2011-2014 Mustang GT 34 11-19-2011 11:32 PM
Is it Worth it jjsg09 1996-2004 Mustang GT 14 10-14-2011 12:26 PM
Is this diagnostic code reader worth getting? scorpiouno 2005-2010 V6 Mustang 2 09-09-2011 03:19 PM
Are these worth buying Carlos92 Pre-2005 V6 Mustang 5 08-01-2011 07:21 AM
Is this fuel gauge worth getting? scorpiouno 2005-2010 V6 Mustang 2 07-17-2011 02:28 AM
06:08 PM
