HID kit... They were flickering now they are stuck in hi beams any suggestions ? - Mustang Evolution
Old 10-21-2011, 11:56 AM   #1
RedGT04's Avatar
When we were installing the ballasts we were using 2 wires and my lights started flickering ... Then we conected two wires which I'm guessing they r hi/lo beams and so they r stuck in hi beams but that's the only way we got them to work ... How to I get rid of that problem
RedGT04 is offline   Reply With Quote
Old 10-21-2011, 01:26 PM   #2
GTtopgear's Avatar
My guess would be to change your fuse
02 GT : LT headers, H pipe, Cat back, 80mm TB, Intake, Strut tower bar, lightweight pullies All BBK, drilled and slotted rotors, Clear headlights, Eibach Pro Kit, Hid kit for both head and fog, chin spoiler,18' chrome 2010 GT wheels with nitto tires
GTtopgear is offline   Reply With Quote
Old 10-21-2011, 03:20 PM   #3
It's not me, it's you.
primer2tone's Avatar
Have they ever worked properly?
You've likely got a bad relay on the relay harness.
Old 10-21-2011, 05:21 PM   #4
RedGT04's Avatar
They weren't on my car but to answer your question they were working properly
Old 10-21-2011, 07:20 PM   #5
back n a stang's Avatar
Re: HID kit... They were flickering now they are stuck in hi beams any suggestions ?
^+1 ....It's that or some gremlin type thing going on.
Old 10-21-2011, 08:24 PM   #6
Were they on another Mustang? Same Gen?
Old 10-21-2011, 09:31 PM   #7
RedGT04's Avatar
No an expedition
Old 10-21-2011, 10:09 PM   #8
That might be your problem. Even though the Expedition might have the same plug, it still might be pinned differently. The sure way to find out is to put that kit back on the Expedition and see if it works then.
Old 10-22-2011, 12:27 AM   #9
Ruthless's Avatar
First and foremost problem is probably going to be the pin out and possibly the bulb type. If I were you I would contact an hid seller and ask if the kits for both those cars are the same. Make sure you have a compatible kit for your car...
Ruthless is offline   Reply With Quote
Old 10-22-2011, 11:34 AM   #10
RedGT04's Avatar
Yeah but it still doesn't make any sense.... Do any o u guys know how to have the fog lights and my hi beans I guess on together ? I just lower my head lights so thy r not too bad on other people
Old 10-22-2011, 12:20 PM   #11
Ruthless's Avatar
How doesn't that make sense? If the kit you are using isn't designed for your car then there's a good chance it won't work. There's alot more involved in a light bulb than just 12 volts... Where you put the voltage wether it's a two filament bulb or not and how many amps either circuit draws... Be my guest to start hacking on your wires but beware when you start back feeding into your ecu you can fry something or keep blowing fuses... Get the right kit...
» Members Mustangs
R1
Untamed5.0
Ellie
sherv33
Add your Mustang
06:11 PM
