2v and 4v blocks - Mustang Evolution
Old 10-21-2011, 02:37 PM   #1
deadhorse's Avatar
2v and 4v blocks
Are the 2v blocks and 4v blocks the same or is there a difference?
deadhorse is offline   Reply With Quote
Old 10-21-2011, 04:20 PM   #2
t0t4lbl4ck0ut's Avatar
Yea they are the same thing. The only difference is if its cast iron or aluminum and Windsor and Romeo blocks
t0t4lbl4ck0ut is offline   Reply With Quote
Old 10-21-2011, 05:09 PM   #3
deadhorse's Avatar
Is that got Anthony to do with the 6 or 8 bolt flywheel?
Old 10-21-2011, 05:12 PM   #4
Yea and the number of bolts for the heads and pulleys
Old 10-21-2011, 05:15 PM   #5
deadhorse's Avatar
Which one is which?
Old 10-21-2011, 05:29 PM   #6
Romeo have 11 bolt valves covers
Old 10-21-2011, 06:03 PM   #7
deadhorse's Avatar
So my remeo heads only fit a remeo block
Old 10-21-2011, 06:13 PM   #8
Yea unless there is some for of kit but I don't see how it would be possible
Old 10-22-2011, 07:02 AM   #9
onesickstang01's Avatar
You can put 2v 3v or 4v heads on any 4.6 or 5.4 block. They are all the same and use the same head gaskets. The blocks are basically the same although very minor difference in romeo windsor and teksid but to answer your question yes the heads all swap over
onesickstang01 is offline   Reply With Quote
Old 10-22-2011, 12:22 PM   #10
Lol I'm an idiot and didn't even think about the stupid valve cover bolts wouldn't affect the mounting of the heads lol IDIOT lol
Old 10-22-2011, 06:18 PM   #11
deadhorse's Avatar
Lol yeah I caught that
Old 10-23-2011, 10:23 AM   #12
But if I was you I wouldn't worry about swapping to cobra heads. Get a good pair of 2v heads and it will do you plenty of good. Plus the 4v are much more to build since their double everything in the valvetrain
---------- Post added at 04:23 PM ---------- Previous post was at 04:19 PM ----------
I cammed my car for roughly 700 and that's with comp cam custom grinds so the cams weren't cheap. to do that In a 4v is gonna cost you 1200 for the cams alone. Sure they may breath better but I honestly believe in the 2v capabilities. People overlook it because of the 4v and 3v but the 2 can be made into just as much of a monster as them.
Old 10-23-2011, 01:33 PM   #13
deadhorse's Avatar
Yeah but I am not trying to build mine up. I'm just trying to get it running again I spun a rod bearing and a buddy has a 4v motor and I was just going to get the block. I didn't know if it would match up.
Old 10-23-2011, 07:08 PM   #14
It will be more of a hassle cause you have to buy a bunch of thing to get it to work then get it tuned
Old 10-23-2011, 11:00 PM   #15
deadhorse's Avatar
I found a 2v intercepter for like 500 is that good or bad ? Has 108k on it and I can hear it run b4 I buy it. What do u think?
Old 10-23-2011, 11:39 PM   #16
For a whole motor that's pretty good. Just make sure it's in 100% working order first
Old 10-24-2011, 06:32 AM   #17
KATO's Avatar
Re: 2v and 4v blocks
Keep me posted on how, all that works out in the end.
Old 10-24-2011, 09:38 PM   #18
deadhorse's Avatar
Will do!
Old 11-10-2011, 08:03 PM   #19
32vNomad's Avatar
Get the 4v motor use your heads. But have your heads/valves inspected and cleaned (metal shavings travel thru out the engine). The block will interchange np. But u will have a bump in compression do to the small dished pistons. If your gettng a mark motor then everything will bolt up to the crank being they are 6 bolt crank. If u have questions pm me I'll help u as much as I can.
32vNomad is offline   Reply With Quote
Old 11-14-2011, 06:55 AM   #20
KATO's Avatar
05:47 PM
