Major Mustang Upgrade - Mustang Evolution
Old 10-23-2011, 08:35 PM   #1
504 Stang Rida's Avatar
I have a 02 GT its dam near completey stock and I came stand it. So now I want to rebuild my block so I can add some serious power. I'm looking to have all forged internals...new heads, cams everything except a Supercharger or turbo kit...so I need help with the best forged rotating assembly internals for the price every kit I see are $1,000 to $1,500...so I know you all can help me out
504 Stang Rida is offline   Reply With Quote
Old 10-24-2011, 05:05 AM   #2
Re: Major Mustang Upgrade
That is about the price of forged internals. They are not cheap. And if you go cheap you will regret it later when you rebuild again and have to replace more cause you went cheap.
Just some idea's.
Shortblock sub menu
http://www.modularmustangracing.com/...Shortblock.htm
http://www.modularmustangracing.com/...shortblock.htm
Old 10-24-2011, 07:22 AM   #3
t0t4lbl4ck0ut's Avatar
Wow 1000-1500 for forged internals. That's cheap. I was looking at eagles rotating assemblies for 2k and thought they were pretty cheap.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 10-24-2011, 02:59 PM   #4
DaBluedude's Avatar
for a fully forged bottom end... with pistons to match bore... 2200$ for a setup good for about 800hp sounds about right. If you can do all the work yourself. If you want new heads, cnc ported etc etc etc... your looking at a lot of money. A set of cnc heads will run you another 2-3 grand and you've still gotta find a nice cam, valves, springs, etc etc etc ... ARP bolts too... Its not cheap but you could build a monster NA car with 7 grand in parts. If your just doing the bottom end then your not really getting anything for it now. But fully forged, 9:1 compression or lower, and you could dump upwards of 20lbs of boost through the right heads...
Old 10-24-2011, 03:46 PM   #5
I'm looking more in the 650 HP range and I was gonna go wit DSS strip/street forged kit tha can handle up to 700hp for $1,500 and I was gonna go trick flow twisted wedge heads with there stage 3 cams with there intake package for $3,200...there heads kit assembly suppose to take a stock engine to between 360 to 390 HP alone
Old 10-28-2011, 11:41 AM   #6
DaBluedude's Avatar
I dunno about the 360-390 claim there. If you want to make 650 hp your looking at a solid 16-21lbs of boost through quality heads. If you cheap out on a 1500$ lower end rated.for 700 your asking for it imo. 500 and there fine. What are you gonna be doing with the car? And have you looked into the driveline upgrades your gonna need?
2003 Mach 1
Old 10-28-2011, 12:08 PM   #7
With the 4.6 you can make 390 by cams, heads, and intake up to the manifold. They did it in mm&ff on an engine dyno. Of course it's not at the wheels but still, your looking at 340 rwhp
Auto to 5 speed swap 2002Gt 1996-2004 Mustang GT 81 06-16-2014 04:28 AM
Mishimoto radiator upgrade kit Tj88mustang 1979-1995 Mustang GT 6 10-16-2011 12:48 PM
Car upgrade Morgue 2005-2010 Mustang GT 11 10-03-2011 09:53 PM
involves cam upgrade CancerBoi69 2005-2010 V6 Mustang 0 09-12-2011 12:44 AM
2010 pulley upgrade Gibby Saleen & SMS Mustang 13 07-09-2011 12:55 AM
08:03 PM
