Pulley squeal - Mustang Evolution
Old 10-25-2011, 06:48 PM   #1
USAF_stang's Avatar
Pulley squeal
Replaced my serpentine belt and I'm still getting a squeal. It only does it on my AC pulley and only when its actually engaged. Any idea or just deal with it? lol.
USAF_stang is offline   Reply With Quote
Old 10-25-2011, 10:41 PM   #2
Mustang_gt_03's Avatar
Region: New Mexico
Probably because it's brand new & "squeaky clean".
Mustang_gt_03 is offline   Reply With Quote
Old 10-26-2011, 04:15 AM   #3
USAF_stang's Avatar
Lol no it did before I changed the belt. It was the reasoning behind a new one
Old 10-26-2011, 07:47 AM   #4
onesickstang01's Avatar
Take sand paper to all the smooth pullies while the car is running. Sand them smooth. Rubber will build up on them and cause a squeek. Most likely your problem is your tensioner. When the ac is on it puts more stress on the belt and the tensioner probably cant keep up anymore
onesickstang01 is offline   Reply With Quote
Old 10-31-2011, 08:24 AM   #5
BigB227's Avatar
I had the same problem on my '03 Gt, the idler/tensioner pulley would squeal real bad, especially with the A/C engaged. Went to the local pep boys an bought a new idler pulley for around $17. Took about 5 mins to put it on and no more squealing. You might just be better off replacing it but my stangs at 73K miles, the bearings were seazed and the seal was cracked
BigB227 is offline   Reply With Quote
Old 10-31-2011, 08:30 AM   #6
01StangGt's Avatar
Haha I work at pep boys as a mechanic, they are pretty reasonable, thought I would throw that out there.
01StangGt is offline   Reply With Quote
Old 11-02-2011, 07:36 AM   #7
Constantine's Avatar
Darn...same here as well. Glad other people are feeling my pain. So then I might as well change the tensioner and the belt at once. And sand down the smooth pulleys?
Constantine is offline   Reply With Quote
Old 11-02-2011, 12:27 PM   #8
I thing it is u idle pulley, went the bearing gone bad made Thad kind of noise. Take the belt out turn the idle with u hand if the run really fast it is time to changed or put some grease on the bearing, but I recommend change the pulley.
---------- Post added at 01:27 PM ---------- Previous post was at 01:23 PM ----------
The tensor is no necessary to change but if u gone to due go to get the UPR it is the best. I have in stock if u interest
2003CobraSvt is offline   Reply With Quote
After market underdrive pulley 98projectpony Pre-2005 V6 Mustang 12 10-17-2011 04:30 PM
Idler pulley jwhayne0001 1979-1995 Mustang GT 10 08-25-2011 04:48 PM
UD pulley kits t0t4lbl4ck0ut General Car Discussion 3 07-09-2011 09:02 AM
2010 pulley upgrade Gibby Saleen & SMS Mustang 13 07-09-2011 12:55 AM
Water pump pulley Carlos92 Pre-2005 V6 Mustang 6 07-04-2011 07:55 PM
04:35 PM
