Abs light? - Mustang Evolution
Old 10-26-2011, 11:24 PM   #1
Gigerdavid's Avatar
Abs light?
My abs light will be on for a few days and then turn off for a few days and go back and forth???
Gigerdavid is offline   Reply With Quote
Old 10-27-2011, 10:27 AM   #2
Re: Abs light?
mine did the same turned out my module went bad $1300 to fix it (I pulled the instrument cluster and took the bulb out for now) or at least until the price of the module goes down if i was you I would pull each wheel off (use a jack stand they save lives) and check the sensors they are about an inch long and an 1/8 inch thick clean off all the metal shavings they collect it because they are magnetic try that see if it helps
kenco1 is offline   Reply With Quote
Old 10-30-2011, 07:33 AM   #3
Thats what i did and clean them got ridoff that light,
robertoortiz85 is offline   Reply With Quote
Old 10-30-2011, 11:47 AM   #4
Gigerdavid's Avatar
Thanks
ABS light + traction control doesnt work RedGT04 1996-2004 Mustang GT 16 11-12-2015 06:43 PM
Mach 1 ABS module help! DaBluedude SVT Mustang 11 11-07-2011 06:48 AM
Dome light problems 98projectpony Pre-2005 V6 Mustang 2 10-20-2011 10:59 AM
ABS and Track off light On Siendly22 General Mustang Discussion 1 10-18-2011 05:19 PM
ABS light on and track off Siendly22 2005-2010 V6 Mustang 0 10-13-2011 11:51 PM
01:46 AM
