Noise commig from rear end? - Mustang Evolution
Old 10-27-2011, 06:31 AM   #1
MustangGT02's Avatar
Ok the other day I was going to a car show and had two people in the back for the first time. After about 10 miles in traffic my rear end would make a thump noise when I would press on the gas then let off and vise versa. Then I went to the strip (Car did fine) until I got home with all the stuff in tha back and it made a rubbing noise in the back like the weigh had pushed something down enuff to rub. Any Ideas?
MustangGT02 is offline   Reply With Quote
Old 10-27-2011, 07:20 AM   #2
bryanbrock's Avatar
Re: Noise commig from rear end?
Go have it serviced and see if that helps, most shops will do it pretty cheep even jiffy lube will do it. I destroyed my rear diff once showing off in my 98 v6 convertible when I was 17. the car was an automatic and I was reving it up in neutral and throwing it into drive to hot rod it ALL the time till one day the rear gave out. went to the junk yard and put a Gt rear diff on it.
bryanbrock is offline   Reply With Quote
Old 10-27-2011, 10:12 AM   #3
put a jack under your transmission and give it one pump watch were the cross member and the the tranny connect if the tranny lifts and the car doesn't it is your mount I just had to do my motor and tranny mounts the cheap rubber only lasts about 75,000
kenco1 is offline   Reply With Quote
95 8.8 5Lug Rear End into 87 5.0 Fox mcdonaldnick 1979-1995 Mustang GT 2 10-12-2011 06:03 PM
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
Rear end trouble Dgerow12 Pre-2005 V6 Mustang 15 09-08-2011 03:59 AM
2011 front end noise question. Help please drivinglesson 2011-2014 Mustang GT 15 08-31-2011 01:38 PM
1996 mustang GT rear end gear change soldierdude28 1996-2004 Mustang GT 6 08-24-2011 03:15 PM
04:57 PM
