rear end - Mustang Evolution
Old 10-27-2011, 09:38 PM   #1
G4be's Avatar
rear end
The rear end feels like it moves when I accelerate from 1st gear. It feels like it raises and kind of shifts to the side. I had it inspected and all they found was a bad tie rod and a transmission mount so I got those changed out. But I'm not sure If this is normal. Some guy said that its because of the torque and that a traction bar would fix the problem.
---------- Post added at 08:38 PM ---------- Previous post was at 08:10 PM ----------
Anyone?
G4be is offline   Reply With Quote
Old 10-27-2011, 09:46 PM   #2
93slowstang's Avatar
If its shifting to the right then your friend is right. Torque shifts to the right rear.
Old 10-27-2011, 10:04 PM   #3
Las0mbra's Avatar
+1
Old 10-27-2011, 10:14 PM   #4
G4be's Avatar
Thanks a bunch! I was kind of worried it was something serious.
Old 10-27-2011, 10:18 PM   #5
TrickFlow94's Avatar
Some poly bushing and oversized sway bars will also help stiffen up the rear end.
TrickFlow94 is offline   Reply With Quote
Old 10-27-2011, 10:46 PM   #6
G4be's Avatar
As long as its not going to damage the car I cam live with it.
Old 10-28-2011, 07:32 AM   #7
Re: rear end
jack up the car on jack stands on the frame so the rear hangs down, inspect the bushings etc see if any are messed up. It should not be like that, the car doesnt produce enough hp/tq to cause damage to those components but the bushings can wear/rot and cause issues.
95 8.8 5Lug Rear End into 87 5.0 Fox mcdonaldnick 1979-1995 Mustang GT 2 10-12-2011 06:03 PM
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
Heavy vibration in rear end Blackedout Pre-2005 V6 Mustang 23 09-15-2011 02:35 PM
Rear end trouble Dgerow12 Pre-2005 V6 Mustang 15 09-08-2011 03:59 AM
Rear end advice t0t4lbl4ck0ut 1996-2004 Mustang GT 6 08-07-2011 06:59 PM
08:37 PM
