4.6 bottom end rebuild. Ideas please - Mustang Evolution
Old 10-28-2011, 01:25 AM   #1
SonicBlueGT9963's Avatar
Long story short I spun a rod bearing , check my other thread to see pics of how it happened. I have a 96 mustang gt , mods are PI intake, PI headswap, MHS stage 3 cams, longtubes , 24lb injectors , Full exhaust , and a few other bolt ons. I have the entire block disassembled and I have to replace the crankshaft, and rod bearings, I don't really have a ton to spend on this but I would like to upgrade while it's all apart. Any ideas that won't break the bank to bad?? I've looked into boring, stroker, different rotating assembly's. Etc. Anything that would give it a little more hp. Open to ideas please let me hear them if u know what ur doing with the 4.6. Thanks !
SonicBlueGT9963 is offline   Reply With Quote
Old 10-28-2011, 08:34 AM   #2
Re: 4.6 bottom end rebuild. Ideas please
i would consider good rods/pistons/crank for a good foundation but that might be a bit to costly.
Old 10-28-2011, 09:36 AM   #3
t0t4lbl4ck0ut's Avatar
It really depends cause if your going to do even more to it like supercharging then I'd tell you to wait till you got some more cash for forged. But if your not going that crazy I'd just order some hypers from summit or wherever you can find them. A crank will run you about 350 or so. You can stroke it easily but bore is a little harder since it has to be machined
t0t4lbl4ck0ut is offline   Reply With Quote
Old 10-30-2011, 12:20 PM   #4
fish's Avatar
How bout porting the pi heads? That should give u some 20+
MAC long tubes; Pipes x-pipe and cat-back; MM kmem, a-arms, camber plates, bump steer; Afco front coilovers; UPR rear coilovers and uper/lower control arms; Flaming River manual steering shaft
fish is offline   Reply With Quote
Old 10-30-2011, 01:12 PM   #5
That's what I'd suggest doing. It's cheap and can get you some extra power and you can do it yourself easily with the right knowledge. Then you can get a valve job and have larger valves so more flow
Old 10-30-2011, 03:38 PM   #6
Do u know anywhere that ports for a good price ?? That's a good idea
Old 10-30-2011, 05:11 PM   #7
Nope. I'm gonna do it myself
Old 10-30-2011, 08:57 PM   #8
I thought about that but I guess that stuff can get messed up if the flow numbers are off
Old 10-30-2011, 10:02 PM   #9
fish's Avatar
www.totalengineairflow.com
Old 10-30-2011, 11:45 PM   #10
The only way you can really do damage is if you don't make them the same size. I mean no it won't be as good as a cnc head but it will get the job done almost just as well
Old 10-31-2011, 08:12 AM   #11
shsfresh87's Avatar
Region: West Virgina
If u haven't already, get some different gears, I like 4.10s but that's with an auto
shsfresh87 is offline   Reply With Quote
07:19 PM
