pulleys - Mustang Evolution
Old 10-29-2011, 09:58 PM   #1
pondit0's Avatar
pulleys
How long will it take to change the pulleys?
pondit0 is offline   Reply With Quote
Old 10-30-2011, 01:58 AM   #2
t0t4lbl4ck0ut's Avatar
You'll need a special tool to get the crank off. But other then that I shouldn't take more then an hour or so
t0t4lbl4ck0ut is offline   Reply With Quote
Old 10-30-2011, 07:01 AM   #3
Yeah u migth do it in 30 if you got your tools and parts ready and a torque/impac gun for alternator pulley if not you need to get it remove by local mecanik sow an hour max . i put on my ramps, then loose the water pump bolts,remove belt,remove the crank bolt, place the removal tool, put the new pulley, tight it whit longer bolt,torque it, put new water pump pulley, put belt back,torque water pump bolts, that took me less than 30, and another 30 to drive to the local mecanik and had the alternator pulley swap because i dont have a torque/impac gun, plus $20bucks he charge me.
Sow is a pretty eazy install. Just have a free morning and have fun doin it.
robertoortiz85 is offline   Reply With Quote
Old 10-30-2011, 12:46 PM   #4
shsfresh87's Avatar
Region: West Virgina
Took me and my dad bout hour or so
shsfresh87 is offline   Reply With Quote
Old 10-30-2011, 05:12 PM   #5
pondit0's Avatar
Thanks guys.
Old 10-31-2011, 08:21 AM   #6
Re: pulleys
I dont believe GT's in 99-04 have a balancer made in with the pulley, if not then its easier to deal with. Else you need an impact gun to remove them both.
Old 10-31-2011, 10:33 AM   #7
stampde's Avatar
Re: pulleys
Spec , yes they do ,the balancer and crank pulley are 1
2011 GT Auto
Pulleys? GTdevildriver 1996-2004 Mustang GT 9 07-09-2011 07:20 AM
06:56 PM
