2004 GT 315 Tire Rubbing Issue - Mustang Evolution
Old 10-31-2011, 01:08 PM   #1
TheJigShow's Avatar
So I have 315 rear tires on 10.5 wide wheels on the back of my 04 GT. There are no clearance issues that I can see from a standstill. However, when I go for a drive and get out, there's cut marks into the sidewall of the tire (only on driver side). My friend also said when following me, I hit a bump on the highway, causing the tire on the driver side to scrape the inner lip of the quarter panel and saw tire smoke come off the tire. Note that this doesn't happen on the passenger side, which is only because I'm only on the driver side, weighing it down.
What should I do to prevent this? My car is lowered, but it's on the stock springs that were cut. Would putting on H&R Springs or an Eiback Kit make it stiff enough that it won't bounce into the fender well, scrape the panel, and mess up my tire and the quarter panel? The rear has been lowered about an inch from factory, and despite the other springs would make it lower, I feel it would make it stiff enough to keep it from having problems.
"Jig"
2014 Ford Focus ST (ST3, Tuxedo Black Metallic)
1997 Ford Mustang GT (Rio Red) (RMR #7832)
2003 Ford Mustang GT Centennial Edition (Black) (SOLD)
2004 Ford Mustang GT (Redfire) (SOLD)
1985 Chevrolet C10 Custom Deluxe (Red) (SOLD)
TheJigShow is offline   Reply With Quote
Old 10-31-2011, 01:25 PM   #2
DarkShadows's Avatar
You need to get your fenders rolled. Call some of your local wheel shops. someone should know someone that can do it.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 10-31-2011, 02:43 PM   #3
TheJigShow's Avatar
Re: 2004 GT 315 Tire Rubbing Issue
Ok. Will that work 100%? And will putting the lowering springs actually help?
"Jig"
Old 10-31-2011, 04:20 PM   #4
ksrumbel's Avatar
I have my car lowered 2" with real lowering springs and 315s. I have no rubbing issues.
ksrumbel is offline   Reply With Quote
Old 10-31-2011, 06:12 PM   #5
H&R, Eibach or Ford Racing C springs will work. I had 315's on my 01 GT for 9 years with no problems. Changing springs should fix ur problem. I do recommend changing shocks and struts as well.
True Blue is offline   Reply With Quote
Old 10-31-2011, 07:20 PM   #6
TheJigShow's Avatar
Ok sweet. And what brand would be a good choice for shocks and struts. I was thinking tokico.
"Jig"
Old 11-01-2011, 06:01 AM   #7
t0t4lbl4ck0ut's Avatar
Ive been told to stay away from the ford racing springs. I had the same issue but on the pass side from torque. I put h&r race springs and kyb adjustables and the problems gone
t0t4lbl4ck0ut is offline   Reply With Quote
Old 11-01-2011, 07:28 AM   #8
get a different size tire or roll your fenders lol. I had to roll mine a bit and i still have a SLIGHT rubbing issue....
if you do roll them thee is no need to fully roll them, you just need to roll them a tiny bit.
Old 11-06-2011, 07:03 AM   #9
fish's Avatar
If u in south Florida, Artic Custom Wheels n Tires do the fender roll with the rolling tool (ask for Roan). 3730 W. Broward Blvd 954-321-1031.
MAC long tubes; Pipes x-pipe and cat-back; MM kmem, a-arms, camber plates, bump steer; Afco front coilovers; UPR rear coilovers and uper/lower control arms; Flaming River manual steering shaft
fish is offline   Reply With Quote
Old 11-07-2011, 10:19 AM   #10
TheJigShow's Avatar
Sadly I live in South Jersey so I won't be able to go there. And I was thinking H&Rs anyways. If it still doesn't work I'll just roll the fenders then.
"Jig"
Old 11-13-2011, 01:17 AM   #11
Topless04GT's Avatar
has the car ever been in a wreck? im lowered 2.5 inches runnin a 315 and i have no rubbing issues on the rear, and im running a 275 up front and have no rubbing issues there either, even without the front sway bar
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 11-13-2011, 07:31 AM   #12
TheJigShow's Avatar
No thankfully not. It's just that side but between the stock springs being cut and me being a...well, not a light person, it has the rubbing issue.
"Jig"
Stock tire size for 00 gt wheels? Horseplay Mustang Wheels & Tires 6 11-03-2011 02:51 PM
2004 40th ann. GT mcvicar04 1996-2004 Mustang GT 2 09-29-2011 08:23 AM
2004 GT Running Royal Brooks04 1996-2004 Mustang GT 0 09-20-2011 04:40 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
09:05 AM
