spudder - Mustang Evolution
Old 10-31-2011, 02:50 PM   #1
pondit0's Avatar
spudder
Mustang is spuddering. It only does it sometimes. Any ideas what it could be? I just changed the plugs and wires.
pondit0 is offline   Reply With Quote
Old 11-01-2011, 12:46 AM   #2
TrickFlow94's Avatar
Possibly fuel filter.
TrickFlow94 is offline   Reply With Quote
Old 11-01-2011, 12:53 AM   #3
Dion11197's Avatar
Re: spudder
+1
Dion11197 is offline   Reply With Quote
Old 11-01-2011, 05:38 AM   #4
t0t4lbl4ck0ut's Avatar
Possibly bad cats, or o2 sensor
t0t4lbl4ck0ut is offline   Reply With Quote
Old 11-01-2011, 06:25 AM   #5
Is it a rattleing spudder or an engine wants to die spudder?
Hawk is offline   Reply With Quote
Old 11-01-2011, 10:48 AM   #6
pondit0's Avatar
It's a spudder like its choking. It has a lot less power too.
Old 11-01-2011, 11:22 AM   #7
bryanbrock's Avatar
Re: spudder
you sure you put the plug wires back on in the right format
bryanbrock is offline   Reply With Quote
Old 11-01-2011, 11:27 AM   #8
You checked for codes? That sounds exactly like what mine was doing. Like at a coast it will be fine then just start bogging the be fine. You gettin worse mpgs
Old 11-02-2011, 07:33 AM   #9
Constantine's Avatar
Fuel filter or fuel injectors I'd say. Mine is starting to do that too. More noticeably when I transition from 1st to reverse. It almost shuts off on me for some reason.
Constantine is offline   Reply With Quote
Old 11-02-2011, 12:10 PM   #10
pondit0's Avatar
A check engine light finally came on. I had it checked out by AutoZone. The test said it was a coil pack. I got a new one and its all good now.
Old 11-02-2011, 03:05 PM   #11
Dion11197's Avatar
Nice! Wouldn't be a bad idea to replace the others... I've heard of others having that problem and once one went the others weren't far behind.
Old 11-02-2011, 06:58 PM   #12
pondit0's Avatar
I heard the same thing but they are like $42.00 a piece. Times that by 7 more and your broke. I'll change them as they go.
Old 11-02-2011, 07:38 PM   #13
Dion11197's Avatar
I know the feeling! It sire adds up quick!
05:19 PM
