Pi swap - Mustang Evolution
Old 11-01-2011, 10:39 PM   #1
96 stang's Avatar
Pi swap
I am thinking of buying some Pi heads from a friend with upgraded valve springs and no cams but I was going to use my stock cams. Will this work And is there anything else I need besides heads & the intake?
96 stang is offline   Reply With Quote
Old 11-02-2011, 08:27 AM   #2
96 stang's Avatar
Can anyone help?
Old 11-02-2011, 09:04 AM   #3
Re: Pi swap
ive heard cams are a big part of it, and if you are going through the swap why not do cams as well? dont do the work later on do it while you are putting it all in.
Old 11-02-2011, 05:21 PM   #4
96 stang's Avatar
I was thinking of that but i don't have $500 for cams. Will I need that special alt. Bracket needed for those years
Old 11-11-2011, 06:46 AM   #5
fish's Avatar
Make sure the intake is pi as well. If that's all you wanna do, then u good. U can later get stage two cans and port the pi heads. If u add long tubes u'll be around 350-400 HP
---------- Post added at 08:46 AM ---------- Previous post was at 08:44 AM ----------
And please research if your non pi exhaust manifold will fit tho. That part I'm not sure
MAC long tubes; Pipes x-pipe and cat-back; MM kmem, a-arms, camber plates, bump steer; Afco front coilovers; UPR rear coilovers and uper/lower control arms; Flaming River manual steering shaft
fish is offline   Reply With Quote
Old 11-11-2011, 09:24 AM   #6
Eturner's Avatar
If you can then wait before you do the install and do the cams at the same time... It'll save you some time and money in the long run...
Old 11-11-2011, 09:47 AM   #7
96 stang's Avatar
I'll check if they fit. Thanks
Old 11-21-2011, 11:16 PM   #8
96 stang's Avatar
So the Pi swap is done. Thanks for all of your guys's help. But for some reason, when I started it, it made this like clacking noise. could this just be the tentioners still needing to take slack out?
irs to sra swap Black99Snake SVT Mustang 4 08-23-2011 09:41 PM
Pi engine swap Kurlywhiteboy 1996-2004 Mustang GT 0 08-14-2011 09:48 PM
Pi engine swap question Kurlywhiteboy General Mustang Discussion 0 08-14-2011 01:56 PM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
2000 3.8 ยป 4.6 swap mustang newb sethhawk1 Pre-2005 V6 Mustang 14 07-28-2011 10:41 PM
11:49 PM
