egr - Mustang Evolution
Old 11-04-2011, 11:15 PM   #1
edgar_32's Avatar
egr
What does a stang do when the egr valve needs replacement?
edgar_32 is offline   Reply With Quote
Old 11-05-2011, 12:37 PM   #2
BigB227's Avatar
Rough idle and poor acceleration
BigB227 is offline   Reply With Quote
Old 11-05-2011, 03:12 PM   #3
Nate98stang's Avatar
My car was tested at Autozone said it's an egr issue idles...ok but accelerates horribly unless at 1/2-3/4 throttle
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 11-07-2011, 08:57 PM   #4
blackdreams15's Avatar
Does it have an aftermarket cold air induction? Just curious because i had the problem for months and it ended up being the induction switch it back and havent had the problem since! Just a suggestion!
blackdreams15 is offline   Reply With Quote
Old 11-09-2011, 07:33 PM   #5
edgar_32's Avatar
Yeah i doo, soo that can be causing the problem?
Old 11-10-2011, 07:16 AM   #6
Yep its very possible! What kind of cai do you have? I got mine off ebay cuz it was cheap n i jus wanted to try it and see what it was about!
Old 11-10-2011, 08:51 AM   #7
edgar_32's Avatar
Re: egr
Ummm i dont really know when i bought the car it already had it.
Old 11-11-2011, 06:13 PM   #8
94 Mustang GT's Avatar
Not necessarily, it could be stuck closed. Then in that case it would be terrible mpg's.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 11-11-2011, 11:25 PM   #9
86 muscle's Avatar
Is there a way to check an egr valve? If so how? My Stang runs pretty rough at times and gets bad mileage
86 muscle is offline   Reply With Quote
Old 11-14-2011, 12:51 PM   #10
Yeah one way to see if it's stuck open is to disconnect the vacuum line at idle and it runs better its stuck open.
1994 Mustang GT
EGR troubleshooting? Nate98stang 1996-2004 Mustang GT 3 11-04-2011 01:23 PM
Project NeedSomeMods 1979-1995 Mustang GT 39 10-24-2011 09:00 AM
Vacuum lines coming from passenger fender well.? Otlaw80 1979-1995 Mustang GT 3 08-15-2011 07:01 AM
Egr valve and evr tbonestang 1979-1995 Mustang GT 18 08-03-2011 04:59 PM
egr hole? workmail21 1979-1995 Mustang GT 1 07-26-2011 08:19 AM
11:48 AM
