howdy. - Mustang Evolution
Old 11-08-2011, 07:12 AM   #1
howdy.
Hey guys. I am new to these forums. More of a researcher/reader than a poster.
Here is my story. I own a 98 GT I purchased for an everyday driver. Atm its sitting at 280k miles on odometer. Now... its a constant 10 miles over on speed. So it should be less miles. About 5 months ago it overheated on me driving down the interstate. When I pulled over it sounded like it was knocking something awful. At that point I had it towed home and it sat.
About 2 months ago I did an oil change and messed with radiator and added fluid. It started right up and sounded great. I saw my cap had a built in thermostat that was locked open. So I replaced the cap and it never overheated again.
Now to my questions. Is there anything I need to be worried about that may have happened due to overheating. It no longer knocked after that day. It tuns and sounds great for a 300k mile engine. Should I replace anything else just in case before I start driving it again?
Now I plan on putting in a low mile pi engine within the next few months. But need another vehicle to drive. Will this last a few months?
CapnMorgan is offline   Reply With Quote
Old 11-08-2011, 07:33 AM   #2
KATO's Avatar
Re: howdy.
Just check your basic stuff for 300K miledge. Filter(s), Oils (eng/tran/rear end), Plugs/Wires, Brakes/Fluid, Radiator, Battery, Tune-up. After that you should be good for a while.
Old 11-08-2011, 10:20 AM   #3
Ok cool. You don't think the overheating before could have caused unseen harm? Although it is running nice now
Old 11-09-2011, 06:21 AM   #4
KATO's Avatar
Re: howdy.
No, I think you are fine now.
Old 11-09-2011, 09:19 AM   #5
wereKEV's Avatar
Re: howdy.
Sounds like everything is good just keep an eye on it.
wereKEV is offline   Reply With Quote
Old 11-09-2011, 09:37 AM   #6
Ok Thx. Will post some pics of her when she running. She just a basic gt atm. Only mods are magnaflow magnapacks. Will drop a 99-04 pi engine in next year with headers and off road x pipe. Then prolly some wheels
Old 11-12-2011, 03:16 PM   #7
Update. For new key. Got it running. Flushed radiator. Only gets hot while driving. Gonna drop in 180 degree thermostat.
Old 11-12-2011, 04:17 PM   #8
Beav's Avatar
Re: howdy.
You don't have any gray/whitish froth in your oil, do you?
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 11-12-2011, 04:27 PM   #9
Not last I checked. But I will recheck now that its running again when I get home
Old 11-13-2011, 11:59 AM   #10
No milky oil. But still knocking when I get on it. Guess I will just look for another motor
Old 11-13-2011, 08:42 PM   #11
SSC182's Avatar
Do not put a 180 thermostat in the car that will not make it run cooler all that will do is open the thermostat sooner the car will still run at its operating temp as it did before it just takes longer to get up to the correct temp. If the car runs at to low of an operating temp your oil will sludge and you will have premature wear on your crank cylinders bearings and so on and so forth
SSC182 is offline   Reply With Quote
Howdy from West Texas 86 muscle New Member Introductions & Greetings 4 10-08-2011 03:11 PM
Howdy howdy MATRIX New Member Introductions & Greetings 7 07-22-2011 09:51 AM
05:23 AM
