Antifreeze in my spark plug well - Mustang Evolution
Old 11-09-2011, 09:30 AM   #1
2002Gt's Avatar
I had a misfire code in cylinder 3, so I pulled out the coil and it was covered with antifreeze. I just flushed my radiator last week and since then It has been spittin and acting like it was goin to cut off. Anybody know what's wrong? Need to know somethin asap! Thanks
2002Gt is offline   Reply With Quote
Old 11-09-2011, 12:56 PM   #2
stampde's Avatar
Re: Antifreeze in my spark plug well
you probably have a small leak up top somewhere , like a hose ? hopefully its not the intake manifold , 4.6 are known to crack ....... anyway where ever its leaking its finding its way into the spark plug holes ..........
2011 GT Auto
Old 11-09-2011, 07:40 PM   #3
2002Gt's Avatar
Yea I'm goin to check everything out tomorrow. It wouldn't possibly be a cracked block? I've been readin around, but I really don't think it's that because I still have all the power as I usually do.
Old 11-09-2011, 09:27 PM   #4
bryanbrock's Avatar
TIME FOR A NEW AIR INTAKE MANIFOLD!!!!!! welcome to the family buddy, that is a common issue for the 96-04 mod motor. swap it with a ford raceing model, you will be happy you did.
bryanbrock is offline   Reply With Quote
Old 11-09-2011, 10:19 PM   #5
2002Gt's Avatar
Well I have been lookin at gettin a new one anyway. My car just rolled over 174,000 miles so I probably needed another
Old 11-10-2011, 06:36 AM   #6
2002Gt's Avatar
Wouldn't the Ford racing one crack too? Or is it like a "stronger" plastic?
Old 11-10-2011, 01:58 PM   #7
bobsurvives's Avatar
Mine cracked at 172,000 miles lol
bobsurvives is offline   Reply With Quote
Old 11-10-2011, 08:39 PM   #8
SSC182's Avatar
If your worried about a cracked block, cylinder head or head gasket take your radiator cap off start the car and check to see if the coolant is bubbling if so this could indicate any one of the three above
SSC182 is offline   Reply With Quote
Old 11-10-2011, 09:07 PM   #9
2002Gt's Avatar
I flushed my radiator last week and its weird because it didn't start spitting until after I did it. I put 1 gallon of antifreeze and the rest water. It doesn't get real cold down here in georgia so that's why I only put 1 gallon.
Old 11-10-2011, 09:37 PM   #10
SSC182's Avatar
Make sure you use a 50/50 mixture of coolant and water I'm from NC and that's plenty of protection from cold a 50/50 mix is good to about -40F
Old 11-10-2011, 10:18 PM   #11
2002Gt's Avatar
Sure will! I just can't believe how much antifreeze is now. It's crazy
Old 11-10-2011, 10:39 PM   #12
SSC182's Avatar
Another thing you can do to check about a head leak is start your car and if you smell a sweet smell coming from your exhaust your getting coolant into the cylinder somewhere
Old 11-10-2011, 11:35 PM   #13
deadsp0t's Avatar
Always 50/50 always. If you just flushed you could have an air pocket that will create a 'hot spot' which could cause a blown gasket or cracked manifold from the heat and or added pressure.
That's unimpressive
Old 11-11-2011, 06:03 AM   #14
2002Gt's Avatar
I'm dropping my car off at my uncles this mornin and we are goin to look at it this weekend.
Major Engine Trouble With Spark Plug Coils 504 Stang Rida 1996-2004 Mustang GT 4 09-29-2011 03:38 PM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 10:45 AM
Spark plug and coil pack sudgestions? p1blake04 1996-2004 Mustang GT 11 08-30-2011 06:18 PM
How Do I Clean Out My Holes? ...spark plug holes? Nel86 General Car Discussion 8 08-06-2011 04:55 PM
Spark plug blown out of head. 1bad2v 1996-2004 Mustang GT 17 07-03-2011 09:29 PM
08:02 PM
