The 96-98 engine. - Mustang Evolution
Old 11-10-2011, 04:32 PM   #1
The 96-98 engine.
Give me your honest answers here. My mechanic keeps telling me to stay away from these gt's because of head problems? Have any of you had these problems? I don't plan on modding a gt too much, maybe just exhaust, cold air, tuner. Thanks in advance.
Undecided SN95 is offline   Reply With Quote
Old 11-10-2011, 05:01 PM   #2
deadsp0t's Avatar
Get a 99-04 PI motor. They make more power and will be more reliable IMO
That's unimpressive
Old 11-10-2011, 05:28 PM   #3
I figured if I did find a 96-98 GT, that I would eventually swap it out to a 99+ engine once it died. But do they really have problems?
Old 11-10-2011, 05:39 PM   #4
deadsp0t's Avatar
I thought you were talking about just a motor, your talking about the whole car huh?
That's unimpressive
Old 11-10-2011, 05:43 PM   #5
Supersnake4.6's Avatar
No I love my sn95 no probloms just keep up with the car oil changes air filter ext.
Supersnake4.6 is offline   Reply With Quote
Old 11-10-2011, 06:33 PM   #6
Eturner's Avatar
What your mechanic might be referring to is that the '94-98 GT did not put out as much power as the '99-04... The heads are different!.. If your car was well maintained then it should be very sound!..
Old 11-10-2011, 07:31 PM   #7
32vNomad's Avatar
Actually the heads in general do have issues with blowing out plugs due to the shallow thread depth. In my case I had a fuel injector on cyl #2 that was running lean. But it does effect all 2v heads and I believe there was a tsb on it as well.
32vNomad is offline   Reply With Quote
Old 11-10-2011, 08:51 PM   #8
deadsp0t's Avatar
94-95 is a push rod 5.0L not a 4.6L. The HP number is 215HP 278TQ for the 5.0L and 215 HP 290TQ for the 4.6L.
Personally I'd not buy a non PI 4.6L
That's unimpressive
Old 11-10-2011, 10:39 PM   #9
DaBluedude's Avatar
I've had a 96 GT for 5 years and its got 400+k km on it. Only problem was a cracked intake manifold. Change the oil and clean the tb once a year. I do burn a bit of oil but its no big deal. There great cars.
2003 Mach 1
Old 11-11-2011, 06:29 AM   #10
onesickstang01's Avatar
Also the radiators and not sufficient in the 96s so it caused alot of overheating/blown head gasket problems
onesickstang01 is offline   Reply With Quote
Old 11-11-2011, 07:07 PM   #11
DaBluedude's Avatar
I've never had a problem. I use royal purple purple ice coolant additive and even in the full heat of summer with the ac on driving hard I don't really have an issue. My mach 1 does run cooler than my 96 tho.
2003 Mach 1
Old 11-11-2011, 08:45 PM   #12
32vNomad's Avatar
But being that its all aluminum is a benifit. But yeah my 02 never gives any issues.
Old 11-13-2011, 09:25 AM   #13
Region: West Virgina
Re: The 96-98 engine.
My Gf has a 98 Gt that has 191K on it no issues other than a cracked intake manifold.Replaced with the aluminum crossover intake still runs decent,But what can you expect for one with 191k on it.Won't run like a new one but still runs strong.
luvmystallion is offline   Reply With Quote
Old 11-13-2011, 10:28 AM   #14
TheJigShow's Avatar
I have a 97 GT. Bought it with 63K and put over 40K on it and overall it's been good. Runs great and pulls hard still. Any repairs that had to be done were once it crossed 100,000 miles or close to it. But as long as you do the required maintenance stated in the owners manual you'll be perfectly fine. As far as issues, usually the issues from 96-98 also carry to the 99-04, except the radiators in the 96s, and the valve stems seals tend to go faster in the 96-98s and cause a tiny bit of oil to pass through. Other than that they're both good.
Performance wise the difference in power between the 96-98 and the 99-04 is down to the poor flowing heads in the 96-98. Also, in the 96-98, the power begins to drop off after 4500 and revs to 6000 while falling on its face, whereas the 99-04's power peaks at 5250 and stays steady to the redline. That could be the issue your mechanic was talking about as well.
What do you have planned if you get one? And you want an auto or 5-speed?
"Jig"
2014 Ford Focus ST (ST3, Tuxedo Black Metallic)
1997 Ford Mustang GT (Rio Red) (RMR #7832)
2003 Ford Mustang GT Centennial Edition (Black) (SOLD)
2004 Ford Mustang GT (Redfire) (SOLD)
1985 Chevrolet C10 Custom Deluxe (Red) (SOLD)
TheJigShow is offline   Reply With Quote
Old 11-14-2011, 10:04 AM   #15
Tib
Tib's Avatar
I think your mechanic was referring to the manifold that cracks on them. My 98GT cracked but not until 120K.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 11-20-2011, 06:52 AM   #16
I was gonna pick up a '96 GT, but I ended up passing on the deal. It was a 5 speed, but my mechanic convinced me to have him build me a fox. :0 Too many problems came from the '96, according to him.
Old 11-21-2011, 11:12 AM   #17
Tib
Tib's Avatar
I'd get a new mechanic...but that's just me.
Old 11-21-2011, 11:56 AM   #18
Haha, it'd be hard to. He's worked on my car since day one. Gave me a deal on everything that's happened. Heck, I didn't pay for everything he did for me. He's a good guy. But one if those typed who prefer carbed applications than efi.
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 12:39 AM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
02:38 AM
