Serpentine belt - Mustang Evolution
Old 11-11-2011, 01:37 PM   #1
Snapple750's Avatar
Serpentine belt
If my power steering pressure line is leaking on my serpentine belt, would I need to replace the belt after I replace the line. The belt is squeaky now.
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 11-11-2011, 02:16 PM   #2
deadsp0t's Avatar
It's possible, sometimes when fluid or water gets between the belt and pulleys the pulleys can spin under the belt causing the ribs to get deeper then normal. If its only been a short time this may not be an issue. I would clean the belt up and try it, if the belt is damaged it will likely make some noise, maybe not right away though. Belts don't cost a lot, I would suggest changing it to avoid any issue at all. Just my opinion though.
That's unimpressive
belt length for no smog and AC eliminated Otlaw80 1979-1995 Mustang GT 8 08-30-2011 12:33 PM
01:47 AM
