Underdrive pulleys - Mustang Evolution
Old 11-13-2011, 08:16 PM   #1
Underdrive pulleys
I currently have underdrive pulleys on my supercharged 4.6. I was wondering if having underdrive pulleys would result in the SC spinning slower (resulting in less boost). Or would the pulleys only affect the part that they are attached to?
mustangt46 is offline   Reply With Quote
Old 11-13-2011, 09:15 PM   #2
t0t4lbl4ck0ut's Avatar
Yes. Underdrives with superchargers are a no no. They slow down the rate of belt spin. Creating less boost. You could just use a bigger pulley on the sc though
t0t4lbl4ck0ut is offline   Reply With Quote
Old 11-13-2011, 09:29 PM   #3
jhagan1980's Avatar
Don't know much about superchargers but wouldn't a bigger pulley slow it down even more?
jhagan1980 is offline   Reply With Quote
Old 11-13-2011, 09:38 PM   #4
I meant a bigger boost pulley lol I should have worded that different
Old 11-13-2011, 09:41 PM   #5
Eturner's Avatar
Under drive pulleys are usually a little bit bigger. If you have a SC with under drive pulleys, then just put a little smaller pulley on the SC to get it back up to it's normal speed.
Old 11-13-2011, 09:55 PM   #6
I have read that if you have a piggyback style pulley you shouldn't use it with a supercharger.
Old 11-14-2011, 12:20 AM   #7
Re: Underdrive pulleys
So just get a smaller pulley for the SC. That sounds simple enough. Does anyone know where I could find a decent set of pulleys to replace my underdrives if I go that route?
Old 11-14-2011, 06:20 AM   #8
onesickstang01's Avatar
You really shouldnt run underdrives with a supercharger. All brands directly say not to. Smaller SC pulley nets more boost
onesickstang01 is offline   Reply With Quote
Old 11-14-2011, 06:37 AM   #9
You can with a steeda because their crank pully isn't a cheap piggy back and will actually handle the pressure on the belt
Old 11-14-2011, 06:53 AM   #10
I wouldnt run any underdrive othet than steeda which is what i had before running my vortech. All SC manufacturers specifically state not to use underdrives. Its not because of the pressure the belt puts on the pulley but the speed at which accessories are spinning. It slows the water pump causing overheating which is made worse by a SC also slows down alternator which with the added fraw of the SC slows it down even more. Also the speeds of the SC pulley are going to slow down, making power come on slower and creates less boost, totally upsetting the tune. There are probaby more issues, belt wrap, belt lengths ect as well. Actually im not sure if i could have even put my vortech on with the steeda water pump pulley
Old 11-14-2011, 08:53 AM   #11
KATO's Avatar
I was also advised not to use UD pullies, and since I do utilize my Audio System, I did not complain at all.
How do i know if ihave ud pulleys NateNasty 1979-1995 Mustang GT 14 11-06-2011 09:32 PM
pulleys pondit0 1996-2004 Mustang GT 6 10-31-2011 10:33 AM
After market underdrive pulley 98projectpony Pre-2005 V6 Mustang 12 10-17-2011 04:30 PM
Underdrive question?? GTdevildriver 1996-2004 Mustang GT 5 08-04-2011 09:18 AM
Pulleys? GTdevildriver 1996-2004 Mustang GT 9 07-09-2011 07:20 AM
05:40 PM
