Exhaust question - Mustang Evolution
Old 11-14-2011, 11:31 AM   #1
Codysmustang's Avatar
Exhaust question
Ok I got a question. My 2002 mustang has flowmaster exhaust on it right now but I think the people that put this on made the pipes for it.. It was wielded from head to toe.. There no h pipe that connects the exhaust to the headers it just straight pipe.. Don't get me wrong it sounds good but I got to change it up some. I looking into getting the borla stinger system from summit racing but if I do get that do I also need to get an h pipe to close the gap?
---------- Post added at 01:31 PM ---------- Previous post was at 01:30 PM ----------
And continuing with that question.. Do I need to get long tube headers or will the ones I have work
Codysmustang is offline   Reply With Quote
Old 11-14-2011, 11:43 AM   #2
CodyNelson's Avatar
Region: West Virgina
You don't need long tubes but they sound amazing! Also, you should look into an h or x pipe. Our motor have proven to perform better with some type of midpipe rather than straight pipes
Old 11-14-2011, 11:49 AM   #3
Well when u get the system from them you have to have an h or x pipe I thought because it not going to be straight pipe.. And I want a mid pipe anyways because I had to cut my exhaust off when changed my clutch.. Not doing that again
Old 11-14-2011, 11:53 AM   #4
CodyNelson's Avatar
Yeah, with the borla's I like an h-pipe. Gives them a little deeper tone
Old 11-14-2011, 12:05 PM   #5
I def gonna have to get that then.. I think that system with the saleen body kit I getting will work together perfectly
Old 11-14-2011, 08:41 PM   #6
CodyNelson's Avatar
It will sound great. Be sure to post a vid of it
Old 11-18-2011, 02:38 PM   #7
I will.. I just don't know when I'll be able to get it.. But as soon as it done y'all will be some of the first to see
Old 11-19-2011, 07:15 AM   #8
That's kinda funny lol, I have a 2002 gt with flowmasters, and I just ordered the borla stinger kit from summit last night
dustin1090 is offline   Reply With Quote
Old 11-19-2011, 08:02 AM   #9
That's awesome.. What mid pipe do you have? I was told get h pipe on here but friends and family say x pipe cuz has better flow.. And where u live cuz def want to hear it
Old 11-19-2011, 08:09 AM   #10
I live in CT. I have the factory catted h pipe. As soon as the kit gets delivered ill take a clip of it
Old 11-19-2011, 08:10 AM   #11
CodyNelson's Avatar
As far as performance both are almost equal. I have read article on testing this and on a 550hp gt the x pipe gained 2 extra hp over the h. So it's really about sound and personal preference m
Old 11-19-2011, 08:15 AM   #12
Sweet thanks for that info.. I def can't wait to get the video Dustin.. Tomorrow I getting the reverse glow on the instrument panel
Old 11-20-2011, 12:25 AM   #13
Ill let you know as soon as the system gets here
Old 11-21-2011, 09:07 PM   #14
MMVEC's Avatar
@CodysMustang you should always have a cross over pipe whether it's H or X in configuration. V-style engines need a cross over in order to balance the pulses between the pistons firing from each bank. Without a cross over, V engines probably lose about 15 to 25 hp. The other issue with not having a cross over is sound. The deep throaty sound you would normally hear if you had a proper cross over is lost-the sound you end up hearing is that of two 4 cylinders ( 3 cylinders if we're talking about V6's and so on for any V-style motor). The first Dodge Vipers did not have cross over pipes due to the side exit systems that the design office wanted for aesthetics and they sounded like they had 5cylinder engines. Chrysler rectified the issue on later cars by running the cross over at the rear bulk head behind the seats--left side of engine exits on right side of car; right side exits on left. This kept the looks design wanted but met the performance criteria.
Bottom line, for maximum power, flow and sound characteristics you need a proper cross over setup.
Hope this helps!
MMVEC is offline   Reply With Quote
Old 11-21-2011, 09:11 PM   #15
Wow that is an amazing bit of knowledge to have.. I def going to get the x pipe when get the system
exhaust
Exhaust leak question drivinglesson 2011-2014 Mustang GT 12 10-17-2011 08:50 AM
Exhaust Question michael81 2011-2014 Mustang GT 30 10-04-2011 10:39 PM
exhaust question... (04 GT) Topless04GT 1996-2004 Mustang GT 7 07-23-2011 04:10 PM
1998 v6 exhaust question?? Gt.Vert Pre-2005 V6 Mustang 6 07-23-2011 12:29 AM
Exhaust question Blackedout Pre-2005 V6 Mustang 4 06-29-2011 08:07 AM
06:08 PM
