2004 GT Tapping (already...) - Mustang Evolution
Old 11-24-2011, 02:26 PM   #1
TheJigShow's Avatar
About five days ago, I thought I had an exhaust leak. After my mechanic had a look/listen, he heard a tap coming from my passenger-side valve cover. To
Be more specific, I was told it was a cam follower causing the tap. In addition, at the same time, the motor that was once silky smooth, seems to vibrate a bit more now. Like you can feel it shake a tiny bit.
This is, obviously, annoying. Is there anything I can do about this? I figured when I do my next oil change (due next week) and add a better fuel (Sunoco or shell vs "Wawa") it'll help reduce it. Will it kill it, or no effect? Plus, should I be too worried? What are your thoughts? Also it seems to go away quite a bit after it warms up.
---------- Post added at 04:26 PM ---------- Previous post was at 04:25 PM ----------
Other notes: it only has 72000 miles and I've only owned it for a little more than 3000 miles.
"Jig"
2014 Ford Focus ST (ST3, Tuxedo Black Metallic)
1997 Ford Mustang GT (Rio Red) (RMR #7832)
2003 Ford Mustang GT Centennial Edition (Black) (SOLD)
2004 Ford Mustang GT (Redfire) (SOLD)
1985 Chevrolet C10 Custom Deluxe (Red) (SOLD)
TheJigShow is offline   Reply With Quote
Old 11-24-2011, 04:17 PM   #2
BigB227's Avatar
Not sure if I can answer your questions but with a high mileage car everything just seems to go lol, my '03 has 74000 and it just seems like I have to keep repairing things lol but I love my stang
BigB227 is offline   Reply With Quote
Old 11-24-2011, 05:03 PM   #3
TheJigShow's Avatar
This is true. My 97 never had this problem though.
"Jig"
Old 11-25-2011, 03:09 AM   #4
t0t4lbl4ck0ut's Avatar
It could be a few things but chances are one or a few of your hydraulic lifters are warn out which would make that noise. I cammed my car and didn't change them and it sounds like a diesel motor because they are warn into the stock cam profile. This would explain why it would lessen after heating up due to expansion, mine does the same thing. They aren't to expensive to buy but it's a pain to replace. You never know till you get in there and start throwing parts at it. Hopefully it's not a bearing cause then your toast.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 11-25-2011, 10:31 PM   #5
TheJigShow's Avatar
I assume you're referring to a rod bearing. How would you be able to tell? For what I know it's not coming from the bottom of the motor, unless that's not a symptom. Also, the noise isn't as intense now and the engine seems to be running smoother. Idk past that.
"Jig"
Old 11-25-2011, 11:43 PM   #6
96 stang's Avatar
Will the ticking go away? I just did a Pi swap & I reused the lifters & I am also getting a ticking.
96 stang is offline   Reply With Quote
Old 11-25-2011, 11:44 PM   #7
TheJigShow's Avatar
UPDATE: It seems the tapping is only when I first start it, then it goes away and I don't hear it anymore. I'm going to add oil stabilizer when I do my oil change next week and see if it helps.
"Jig"
Old 11-26-2011, 07:12 PM   #8
It does lessen but it never goes away unless you replace them
Old 11-26-2011, 07:52 PM   #9
96 stang's Avatar
Will it mess anything up?
Old 11-26-2011, 09:43 PM   #10
No they are just worn to what you previously had. They aren't doing any damage. They are just noisy
Old 11-26-2011, 11:17 PM   #11
96 stang's Avatar
Okay thanks.
Old 11-27-2011, 09:14 AM   #12
TheJigShow's Avatar
Ok so if it's just my follower it won't damage anything, just be annoying?
"Jig"
Old 11-27-2011, 05:55 PM   #13
It's the hydraulic lifters aren't lifting your followers enough and it's makes that tapping noise. It's just annoying. Change your lifters to fix it.
Old 11-27-2011, 05:59 PM   #14
TheJigShow's Avatar
Ok sweet. Thanks for the help guys!
"Jig"
2004 GT 315 Tire Rubbing Issue TheJigShow 1996-2004 Mustang GT 11 11-13-2011 07:31 AM
2004 40th ann. GT mcvicar04 1996-2004 Mustang GT 2 09-29-2011 08:23 AM
2004 GT Running Royal Brooks04 1996-2004 Mustang GT 0 09-20-2011 04:40 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
12:31 PM
