MAF not needed?!? - Mustang Evolution
Old 11-25-2011, 10:32 PM   #1
MustangGT02's Avatar
Exclamation MAF not needed?!?
So the other day I decided to put my AM CAI back on and clean my IAC. I put the CAI on and cleaned the IAC with TB cleaner and started the car... the car started to turn over but didnt, the second time it started and lost rpms then got them back and idled like never before (idled good), I drove it around the block and had to take the IAC off and put back on due to bad gasket and noticed the MAF was unpluged! I pluged it back in and started the car and it idled like normal, the pop and unanble to maintane a smooth rpm. My question is could my car have a tune were it can run with out the MAF?
Also NO LIGHTS CAME ON when the MAF was unpluged!
MustangGT02 is offline   Reply With Quote
Old 11-26-2011, 02:14 AM   #2
I don't see how u would tune out the maf.it is pretty much required to keep the motor running good.as the car and/or air temps change the maf automatically adjust the fuel system.the efi won't work well without it.it should throw a code,just maybe u didn't drive it long enough without it plugged in.also since u drove it without it,it is possible u may have to drive it 20-30 miles to let the ecm relearn its parameters.
Old 11-26-2011, 09:04 AM   #3
DarkShadows's Avatar
Only way to tune out a maf is to run a carb.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Injectors not pulsing? Otlaw80 1979-1995 Mustang GT 21 07-27-2014 03:12 PM
maf shawnpbigelow 1979-1995 Mustang GT 17 10-26-2011 03:37 PM
Building a computer tower... input needed jimmy_beaner The Bar 52 09-06-2011 09:48 PM
MAF t0t4lbl4ck0ut 1996-2004 Mustang GT 4 07-20-2011 12:53 PM
MAF sensor Mustanglife Pre-2005 V6 Mustang 5 07-01-2011 07:22 AM
03:39 AM
