engine tapping after going through a puddle - Mustang Evolution
Old 11-26-2011, 06:24 PM   #1
I have an 01 bullet. i went through a good sized puddle (not intentionally) and my car shut off immediately and took about 1.5 hours before it started again. once i got it started the car ran like sh*t. really rough and now there is a nasty tapping coming from under the hood. the tapping doesnt go away at all and increases and decreases with the RPMs. anybody have any ideas what is wrong???
Myles is offline   Reply With Quote
Old 11-26-2011, 06:33 PM   #2
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Don't run it anymore, change your oil and filter, could have water inside the engine. You don't want to seize up your engine. Also could have just soaked your coil packs and maf, but if it's tapping you need to change your oil asap, just to be on the safe side of thungs
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 11-26-2011, 06:38 PM   #3
SSC182's Avatar
Yeah you sucked water into your motor and hydro locked it. The taping is probably a bent rod or something to that effect. When it sucks water into the motor the pistons cannot compress liquid so it bends the rod which can lead to you throwing one out of your block if you have bent it bad enough.
---------- Post added at 09:38 PM ---------- Previous post was at 09:35 PM ----------
I would definitely not drive it anymore and when you change the oil look and see if there is water in it when you drain it. And to be on the safe side I would take the heads off to make sure all the water is gone
SSC182 is offline   Reply With Quote
Old 11-26-2011, 06:59 PM   #4
It's not me, it's you.
primer2tone's Avatar
You can't compress water. That really blows... That happened to my Nissan a few years ago. It actually bent con rods 1 and 4. Sorry man.
Old 11-28-2011, 06:12 AM   #5
how deep was the puddle and from both sides or just one
robertoortiz85 is offline   Reply With Quote
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 12:39 AM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
12:56 AM
