New engine for the Gt Pics!! - Mustang Evolution
Old 11-27-2011, 08:23 PM   #1
SonicBlueGT9963's Avatar
Ok so long story short i just picked up this motor from a guy for 500 bucks and I need some advice before I put it in.
These are the exact specs that he gave me .
Bottom end
Stock blocked bored .030 over
Has eagle forged and balanced crank and rods and weisco flat top .30 over pistons
90.2 mm stroke
High flow oil pump
Top end has the Windsor PI heads that have been shaved, PI cams
And now the weird part lol. It has been converted over to carbureted with a custom high rise intake manifold and an eddlebrock 750 cfm four barrel.
From what the guy said the displacement is a little bigger than a 5.2 liter and he said its over 400 hp,
Any mustang guys this is where I really need your help I'm gonna drop the oil pan and inspect the rotating assembly to see if I can figure out if it's really forged and what brands if so, I would like to check to see if it's a stroker and bored out but I have not the slightest clue on how to tell.
I know I didn't get ripped off because I saw the motor run on a stand and it was fine all I needed was the assembled block anyways. But I guess my questions are. Should I keep the carb on it? Do the engine specs sound correct? Give me every detail u can on how I can look this motor over and see what exactly I'm dealing with. Thanks guys there's pics below. And I can take more whenever. Help me out lol !!
SonicBlueGT9963 is offline   Reply With Quote
Old 11-27-2011, 08:27 PM   #2
Bottom end
90.2 mm stroke
High flow oil pump
Old 11-27-2011, 08:28 PM   #3
Old 11-27-2011, 08:28 PM   #4
Old 11-27-2011, 08:29 PM   #5
Old 11-27-2011, 08:29 PM   #6
Old 11-27-2011, 09:17 PM   #7
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I'm thinking you will probably need a new hood with more clearance, because the stock injected set up is more low profile. But you wont know until you drop it in. I like the custom sheet metal intake, looks mean.
---------- Post added at 03:17 AM ---------- Previous post was at 03:15 AM ----------
Actually it looks like you might have a cowl hood already.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 11-27-2011, 10:39 PM   #8
Ya. I got a 6 inch cowl on it so it should clear just fine lol.
---------- Post added at 10:39 PM ---------- Previous post was at 10:38 PM ----------
It's kind of like a mystery engine cuz I don't know for sure what I'm getting. Guess I could just put it in and find out. Sounds like fun. Haha
Old 11-28-2011, 07:48 AM   #9
Re: New engine for the Gt Pics!!
your not going to stroker a stock iron block to a 5.2liter without doing sleeves which i doubt it has..whats the stock on the rods and crank? 400 hp with stock cams?hell no lol)
whats the compression since it has flat tops and heads have been milled?
only way to really check and make sure its forged is to do like you said pull oil pan and look...
slow02gt is offline   Reply With Quote
Old 11-28-2011, 08:26 AM   #10
If I remember right the compression is like 11 something. From what he said but who knows , I think when I pull the pan off I'm gonna measure the cylinders and compare the size to my stock block to see if it's bored Idk. Lol
Old 11-28-2011, 08:47 AM   #11
onesickstang01's Avatar
Look for part number on crank rods and piston. That will tell you alot if you can find them
onesickstang01 is offline   Reply With Quote
Old 11-28-2011, 09:06 AM   #12
Brett Greene's Avatar
Not a bad buy for 500 bones bro.
My advice is rip it apart find out exactly what you have and work from there. I would build it up to your goals and you will be happy. Keep the carb to I think it
Looks bad asd
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 11-28-2011, 01:26 PM   #13
with flat tops and milled heads hell it should be about 12 something lol..
Old 11-29-2011, 10:50 AM   #14
Well I went with my gut feeling and pulled it apart and everything is stock lol. The dude totally lied his *** off wow. If u guys buy anything from anyone make sure u check it all out nomatter how nice they are. Damn. Well looks like plan b. I'm gonna use the bottom end of this Motor and put my ported PI heads stage 3 cams langtubes and the rest of my goodies I already have on and get it all tuned after
Old 11-29-2011, 11:12 AM   #15
that sucks!!!! buuuuuttttttttttttttt
i figured what was the case since you got it for 500 bucks lol... i have some scat h beam rods with arp 2000 rod bolts if your interested..$350 bucks takes them only have 5k miles on them..
Old 11-29-2011, 11:15 AM   #16
stampde's Avatar
ya that intake looks cool , but is WAAAAY to Much for a 400hp engine .
it'll run like crap .
go with a Victor Jr or performer RPM intake and sell that race intake
and you'll pick up HP AND RUN A LOT BETTER ALL AROUND
when you take the pan off look at the cyl bores at the bottom ,if it has a stroker it'll have small notches ground off the bottom of the cylinders so that the rod bolts /rods will clear when rotating ..........
2011 GT Auto
Old 11-29-2011, 03:32 PM   #17
What the hell is the deal with the dist
tbonestang is offline   Reply With Quote
Old 11-29-2011, 10:42 PM   #18
Ya it's not a stroker not anything lol its just a stock 4.6. I'm just gonna use the bottom end , I was goin to buy a short block from a guy for 500 so I didn't really get screwed. I blew up my bottom end so that's what I'm gonna use O well thought I was getting a bunch of other **** o well lol
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 01:39 AM
1999 Mustang GT Engine Rebuild Question!!! FORDGT14 1996-2004 Mustang GT 4 09-26-2011 01:10 PM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 03:11 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 06:29 AM
'88 GT check engine light? robert81717 1979-1995 Mustang GT 7 07-13-2011 12:56 AM
11:30 PM
