mustang will not start im confused?? help - Mustang Evolution
Old 11-29-2011, 07:59 AM   #1
mhobbs's Avatar
Ok so when replacing my radiator and deleting my ac i disconnected my abs module. when I hooked it back up I got in my car, turned the key on, a buzzing came from the rear of the car and it will not start as if the computer is telling it not to start. what could cause this??
mhobbs is offline   Reply With Quote
Old 11-29-2011, 01:15 PM   #2
Napoleon85's Avatar
Re: mustang will not start im confused?? help
Fuel pump maybe?
Old 11-29-2011, 09:23 PM   #3
mhobbs's Avatar
no because i hear the fuel pump kick on then off then this still goes on
Old 11-30-2011, 05:25 AM   #4
Unhook your battery for about 30 mins and c if that resets anything. Also check your fuel pressure at the rail to c if u have the right amount of pressure
Robbie94gt is offline   Reply With Quote
Old 11-30-2011, 12:30 PM   #5
DaBluedude's Avatar
Sounds like you tripped the fuel relay. In the trunk behind the left trunk covering (there's a hole actually, no need to remove the trunk lining, there's a fuel pump reset button. Its a red button and is mounted to the framework on the other side of the tail light I think. Hold it down 3-5 seconds. Try again. I've had to reset it a couple times.
2003 Mach 1
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
01:35 PM
