help transmission - Mustang Evolution
Old 12-02-2011, 03:07 PM   #1
1999roush's Avatar
Driving in third and fourth I'm starting to get some chattering. If anybody knows what this could be please let me know
1999roush is offline   Reply With Quote
Old 12-02-2011, 05:25 PM   #2
Re: help transmission
Maybe it's just cold and its teeth are chattering?
Seriously, have you checked the fluid level?
Possibly wear, how many miles are on it?
Old 12-02-2011, 06:28 PM   #3
1999roush's Avatar
Fluid level is good it has 62000 miles and it only does it in 3rd and 4th even when car is fully warmed up.
And lol about the teeth chattering
Old 12-02-2011, 06:58 PM   #4
deadsp0t's Avatar
Had a friend with a similar issue in a 97' GT. then I started popping out of gear and eventually broke and would not stay in gear at all. Car was in the 80k mile range I think. He beat the hell out of that car all the time.
Does it ever grind going in gear, any gear in any situation?
That's unimpressive
Old 12-02-2011, 07:01 PM   #5
1999roush's Avatar
Never grinds going into gears always smooth never pops out of gear. Only when I'm accelerating it does it. Car has not been abused rarely sees over 3000rpm
Old 12-02-2011, 07:06 PM   #6
deadsp0t's Avatar
Damn, hate to hear its acting up when you treat it right. That sucks man.
Do you have an aftermarket shifter?
That's unimpressive
Old 12-02-2011, 08:02 PM   #7
1999roush's Avatar
Yeah I have a pro 5.0 shifter
Old 12-02-2011, 08:26 PM   #8
bryanbrock's Avatar
If it were me I would just take it to a couple of transmission shops for a free estimate just to rule anything else like U-joints out as they will cause you to shimmy and shake in those gears. And lord for bid it is an internal tranny Issue I would drain and refill it adding lucas transmission treatment befor just throwing in the towl. that stuff is wonderful. good luck
bryanbrock is offline   Reply With Quote
Old 12-02-2011, 08:42 PM   #9
1999roush's Avatar
I've heard synchronizers give problems in those gears .......I wonder if that could be it
Old 12-02-2011, 08:45 PM   #10
That sounds like maybe a bearing in the transmission is going out or possibly the clutch is slipping a bit in higher gears.
Old 12-02-2011, 08:46 PM   #11
I guess it is possible, but I would expect you to see other problems first, like grinding or difficult to get into gear.
Old 12-02-2011, 08:57 PM   #12
1999roush's Avatar
I guess I could wait till it flies apart and then I would definitely know what it is lol
Old 12-02-2011, 09:05 PM   #13
Yeah, that's always an option, but if your luck is anything like mine it will do so at the most inopportune time possible.
Old 12-02-2011, 09:08 PM   #14
1999roush's Avatar
I'm dropping it off at the paint shop Monday so ........... probably the next week I will take it around and get a few estimates. Just out of curiosity how much HP and torque is a t45 good for
Old 12-02-2011, 10:18 PM   #15
They don't supply HP just torque ratings.
They are good for around 325 ft lbs.
Web Page - TREMEC T45
Old 12-03-2011, 06:03 AM   #16
1999roush's Avatar
What transmission would u recommend I've got 420 lbs of torque?
Old 12-03-2011, 11:06 AM   #17
351mustanggt's Avatar
for manual the tko 600 would be able to take the 420 ftlbs of torque your making
351mustanggt is offline   Reply With Quote
Old 12-03-2011, 12:35 PM   #18
+1 The TKO 600 would be my first choice.
Anything stronger than that would likely have to be specially built.
Old 12-03-2011, 12:40 PM   #19
1999roush's Avatar
What is the tko 600 good for torque wise
Old 12-03-2011, 01:28 PM   #20
600 ft lbs.
Old 12-03-2011, 04:42 PM   #21
1999roush's Avatar
Thanks for all the help from everybody
Old 12-04-2011, 02:57 PM   #22
You're welcome, we are glad we could help.
Old 12-04-2011, 02:59 PM   #23
1999roush's Avatar
One more question what is the best place to buy one from and what else am I going to need.............well crap that's two questions but o well lol
Old 12-04-2011, 03:39 PM   #24
Check with our forum vendors/sponsors first. They may give you a discount that will help ease the pain in your wallet.
Their forums on here (Support our sponsors) tell how to get the discounts.
I'm not 100% sure what else may be required.
I do know in some cases a different clutch disk is required because of input spline differences.
Check with the supplier you choose to see if there are any other requirements.
6 spd. transmission in Mustang GT made in China Mercedez L. 2011-2014 Mustang GT 24 01-11-2012 08:49 PM
Transmission talk? Brock23 2011-2014 Mustang GT 6 12-01-2011 01:59 PM
Manual Transmission Fluid Napoleon85 2011-2014 Mustang GT 6 11-15-2011 02:47 PM
Choosing a tranny? Hawk General Mustang Discussion 0 10-08-2011 07:41 PM
Transmission problem carlgator 1979-1995 Mustang GT 1 08-14-2011 09:52 PM
04:25 AM
