Help my car has the shakes - Mustang Evolution
Old 12-03-2011, 12:29 PM   #1
Stangplorer's Avatar
Hey guys I'm new here just downloaded it on my phone lol ok so my 2002 gt has the shakes real bad don't have to be moving to feel it ....5 speed anything above 1300 rpm it's like the car is literally gonna explode like my spoiler flexes and vibrates when the engine is revved ... Changed out harmonic balancer last night made it a little better but not really ... Goin to do plugs in a couple hours idler pully bearings shot so doing that too I know that wouldn't cause a shake but it's noisy so I'm doing that also last night replaced a hose coming off Pcv valve going from intake to intake cuz it was collapsed ... I hope it's not a flywheel issue but does anyone have any ideas????
Stangplorer is offline   Reply With Quote
Old 12-03-2011, 02:04 PM   #2
Blogger
99ford's Avatar
Re: Help my car has the shakes
Hmm could be a Bad ignition coil perhaps.
Old 12-03-2011, 02:12 PM   #3
I should also let u kno its not throwing a code too no check engine light which is weird
Old 12-03-2011, 02:12 PM   #4
It's not me, it's you.
primer2tone's Avatar
Before you swap out your plugs try disconnecting one ignition coil at a time. Each time you disconnect one the engine should idle rougher. If you disconnect one and there is no change in idle... That one is your problem.
Welcome abroad btw.
Old 12-03-2011, 02:20 PM   #5
Disconnect while running ?
Old 12-03-2011, 02:52 PM   #6
shsfresh87's Avatar
Region: West Virgina
Thats not good
shsfresh87 is offline   Reply With Quote
Old 12-03-2011, 02:58 PM   #7
What's not good
Old 12-03-2011, 05:35 PM   #8
shsfresh87's Avatar
That ur car shakes
Old 12-03-2011, 05:39 PM   #9
Just did the plugs ... Coil packs r good it's not a misfire there's no check engine light motor mounts look good no play didn't check tranny mounts don't have a lift and don't wanna get ran over by a friend lol ... This is starting to piss me off wtf else could it be ... Like I said there's no check engine light no pending codes nothing ... 3rd gear is grinding 2 to 3 ... Downshifting into 3rd is almost impossible bad synchro I think don't care about that right now I need the shake gone it's a vibration when accelerated neutral or any gear moving or parked .... Sucks lol
Old 12-03-2011, 06:46 PM   #10
Blogger
99ford's Avatar
Let's back up before this how was it driving and running? Did you notice the transmission acting funny before?
Old 12-03-2011, 07:16 PM   #11
Ok... Bought the car real quick when I was home on leave from Afghanistan then went back I bought it thinking it was the hb turns out its not so I really don't know any history on the car for all I know it could have a "new" used clutch in it u kno so I talked with my buddy he's gonna ask his boss I he can use the lift at his work and were gonna put a new flywheel in and a new clutch while we're there ugh I should have kept my beast I had before this one ....2000 gt every bolt on 4.10s nasty car ... Sold it and ya
Old 12-03-2011, 08:17 PM   #12
Blogger
99ford's Avatar
Okay that's what I was thinking, this was a relatively new car, for you I mean. But now you have something new with a whole set of different problems Nothing like a mystery. You may also want to flush the transmission while your at it. What type of gas are you using? Also try replacing the fuel filter and checking the fuel pump. It seems a little out there but it doesn't hurt to check.
Edit: Eventually your going to solve it! Hang in there.
Old 12-03-2011, 08:27 PM   #13
Thx man I'll post what I do when I finally do it and what it was Christmas is around the corner so $$$ tight right now dammit lol all I want for Christmas is my car fixed
Old 12-03-2011, 08:46 PM   #14
Blogger
99ford's Avatar
I hear ya same here and this ****t always happens when you don't have as much!
Old 12-03-2011, 09:23 PM   #15
Exactly
Old 12-12-2011, 08:53 PM   #16
Drose78's Avatar
I just was going through same problem and actually found that injector in #4 was bad..... Changed that fixed the problem 90%...found that gotta change harmonic balancer.. Don't even know what that is or how to replace... Ideas.
Drose78 is offline   Reply With Quote
Old 12-12-2011, 09:01 PM   #17
Is ur check engine light on ?
Old 12-12-2011, 09:03 PM   #18
Drose78's Avatar
No and it never was...... Runs much smoother after injector replaced
Old 12-12-2011, 09:06 PM   #19
I c ... I just dropped mine off this morning to have them drop the tranny and see what's going on (flywheel or clutch) she runs fine ... Just when given any gas above 1500rpm feels like she's gonna fall apart ... What was yours feeling like ... I would think an injector would throw a code u know ... Ran a diagnostic on my car with 4000$ scanner and fuel pressure is fine all cylinders good that's why I'm havin them pull he tranny
Old 12-12-2011, 09:09 PM   #20
Drose78's Avatar
Only found out it was a injector after taking it to get hooked up to diagnosis machine
---------- Post added at 09:09 PM ---------- Previous post was at 09:08 PM ----------
It had a heavy shake especially at idle
Old 12-12-2011, 09:10 PM   #21
Ah I c well I'm hoping for something simple like that don't really want to replace clutch and flywheel $$$$ around Christmas time lol
Old 12-12-2011, 09:21 PM   #22
Drose78's Avatar
I feel ya
Dream Car? JetWolf General Car Discussion 105 12-08-2011 12:29 PM
fast car andyr421 1996-2004 Mustang GT 28 11-13-2011 06:08 PM
97 GT Smelling gas fumes in car Sharky97 1996-2004 Mustang GT 2 09-20-2011 03:54 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 12:10 PM
car shakes when idling austinknoll Pre-2005 V6 Mustang 57 08-17-2011 08:03 PM
04:14 PM
