Idle problems - Mustang Evolution
Old 12-05-2011, 09:56 PM   #1
BigB227's Avatar
Idle problems
For the past couple days when I start my car it will idle real rough and erratic. It will jump from about 1k rpms down to below 500 almost dying, the. It will raise back up an drop continually.
This happens even when the car is in all of the gears like neutral and drive. I can't seem to understand what might be causing this. I popped open my hood and when it's at idle it is erratic and a loud sucking/humming noise can be heard from the intake near the fender wall, it vibrates the engine bay quite a bit.
Any suggestions???
BigB227 is offline   Reply With Quote
Old 12-05-2011, 10:20 PM   #2
96 stang's Avatar
My car did this when I had bad o2's & you might wanna try cleaning the IAC
96 stang is offline   Reply With Quote
Old 12-06-2011, 06:41 AM   #3
BigB227's Avatar
It might be the O2 sensors because I jut cleaned the IAC like 4 days ago. Thanks for the input I'll have to check that out, do you know how I could tel if the O2 sensors are bad or not?
Old 12-06-2011, 08:32 AM   #4
96 stang's Avatar
If you hook up a scanner & view the "live data" the front o2's should be jumping up & down & the rears should be more steady
Old 12-06-2011, 09:35 AM   #5
BigB227's Avatar
Ok thank you for all the help
Old 12-06-2011, 10:57 PM   #6
96 stang's Avatar
No problem
2000 V6 problems iphonemaster93 2.3 Mustang 47 01-12-2012 12:10 AM
idle problems brian94gt 1979-1995 Mustang GT 22 11-21-2011 08:44 PM
Stupid idle NateNasty 1979-1995 Mustang GT 23 10-17-2011 07:12 AM
Idle problems need some help stangrunner 1979-1995 Mustang GT 6 09-16-2011 07:49 PM
Y2k v6 idle problems 6Banger2000 2005-2010 V6 Mustang 4 07-22-2011 07:10 AM
02:18 PM
