starting issues - Mustang Evolution
Old 12-06-2011, 04:51 PM   #1
bostang99's Avatar
starting issues
Anyone ever have issues with their GT starting. My 99 GT doesn't start when its too hot or if I've drivin for more than 30 min. Its just cranks over and over and won't start. The goofy thing is if you let it sit AFTER trying to start it for 30 min, it'll fire right up. Advice? PATS system?
bostang99 is offline   Reply With Quote
Old 12-06-2011, 05:42 PM   #2
sally2002's Avatar
It sounds like a crank case sensor to me
sally2002 is offline   Reply With Quote
Old 12-06-2011, 07:32 PM   #3
02PONY's Avatar
U check ignition switch
02PONY is offline   Reply With Quote
Old 12-06-2011, 07:43 PM   #4
Ilovemustangs88's Avatar
Mine is the opposite if it's below freezing it don't want to start but if it's warmer it starts the first try
---------- Post added at 09:43 PM ---------- Previous post was at 09:43 PM ----------
Mine is a 2000 v6
Ilovemustangs88 is offline   Reply With Quote
Old 12-06-2011, 08:09 PM   #5
Justintriner's Avatar
Mines tricky. Sometimes it starts right up. Other times it takes two cranks to kick it over
Justintriner is offline   Reply With Quote
Old 12-06-2011, 08:41 PM   #6
bostang99's Avatar
Id imagine if it were a crank sensor id get a check engine light and i dont get anything. I was also thinking maybe its my coolant temp sensor reading the car is too hot to start. And the ignition switch tested ok.
Old 12-06-2011, 08:45 PM   #7
Your starter windings may be worn .when they get warm they don't work as good.also check your grounds.
Old 12-06-2011, 10:39 PM   #8
Mile high JDF's Avatar
Mine is a 2000 v6
Have your battery tested. It's probably bad
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-06-2011, 10:41 PM   #9
nickysixx's Avatar
Battery shouldn't have an affect with temperature change like that. Check your starter plus crank case sensor. If the sensor is bad it won't always throw a code.
____________________________________________
1957 Buick Special Estate Wagon
1996 Mustang GT (sold)
1997 Mustang V6 (sold)
2002 Jeep Grand Cherokee Laredo (sold)
2007 Jeep Grand Cherokee
nickysixx is offline   Reply With Quote
Old 12-06-2011, 10:49 PM   #10
I guess I should ask the question if it cranks or not
Old 12-07-2011, 07:42 AM   #11
bostang99's Avatar
I guess that's true...battery tests ok. The car sits with the battery disconnected. Sometimes when it just cranks for 5-6 sec its almost like a switch turns on and it'll start. Its the strangest thing. The crank sensor makes the most sense but i don't wanna tear *** into my motor if it isn't.
Old 12-07-2011, 07:52 AM   #12
Filibuster
I would go with this suggestion!..people sometimes run into this problem after installing headers when they sit close to a starter the starter lags enough to make it hard to start!...simply letting it cool of usually fixes it temporarily..
XXSTEVEO66 is offline   Reply With Quote
Old 12-07-2011, 07:59 AM   #13
bostang99's Avatar
I do have headers...header wrap solve the issue. But i have driving it to work it sits for 8 hours and it won't start right up. I have to try it, let it sit, and retry after 30 min and it'll fire up.
Old 12-07-2011, 09:25 AM   #14
They also make a starter blanket/wrap.it is easier than wrapping the headers.summit racing sells them for 20$.I would still suggest a new starter though.also look into the smaller diameter ones.they will give u more header clearance.
Old 12-07-2011, 10:23 AM   #15
Yeah my car had a new starter on it and one night the water pump went out and it got hot. Use to crank fast amd start right up. But when it got hot it wouldn't start just crank real slow. So I let it set for a while. Then drive it home just mins away. But now I put the new water pump on it amd it still crank real slow but starts up. So I think the windings in the starter r bad now. I also have headers. With no heat wrap on the starter. Does it crank regualar or does it crank slow. If it cranks slow replace the starter
Robbie94gt is offline   Reply With Quote
Old 12-07-2011, 10:46 AM   #16
bostang99's Avatar
Cranks normally just doesn't turn over. Im gonna try starter wrap or header wrap but i have a laundry list of things to try.
Interior Issues? Dion11197 2011-2014 Mustang GT 20 12-05-2011 06:55 AM
Issues cranking 2012 v6 krgorham 2011-2014 V6 Mustang 10 10-30-2011 02:27 PM
2011+ 5.0, lets have a poll on issues DDTCM 2011-2014 Mustang GT 36 09-14-2011 05:56 AM
Starting issues GunMetalBullet 2005-2010 Mustang GT 6 08-06-2011 10:24 PM
Starting Issues bradh2414 Pre-2005 V6 Mustang 25 07-14-2011 08:43 PM
08:37 AM
