NEED HELP PLEASE!!!! - Mustang Evolution
Old 12-07-2011, 02:22 PM   #1
FORDGT14's Avatar
K so I just got the brand new, completely rebuilt 4.6L 2V installed in my 99 GT yesterday. I fired it up lastnight for the break-in, but it idles like hell.. It wont stay idling without me tapping on the throttle. Idk if its a compiter thing or if I did something wrong. Please any info would help. This is a brand new engine and it should be running perfect rite?
Let me know if I left any needed info out, id be glad to fill you in.
Thank you.
FORDGT14 is offline   Reply With Quote
Old 12-07-2011, 02:32 PM   #2
onesickstang01's Avatar
MAF sensor on correctly? All
Connectors plugged in? Idle screw adjusted? Check the iac as well
onesickstang01 is offline   Reply With Quote
Old 12-07-2011, 02:38 PM   #3
Topless04GT's Avatar
Re: NEED HELP PLEASE!!!!
couldnt it also be a vacuum leak?
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 12-07-2011, 02:47 PM   #4
FORDGT14's Avatar
Yes everything is plugged in.. I already checked for vaccum leaks..and I thought these 4.6's didnt hace an idle screw.. Where would it be located?
---------- Post added at 04:47 PM ---------- Previous post was at 04:46 PM ----------
And whats an IAC?
Old 12-07-2011, 03:01 PM   #5
BossMach's Avatar
Idle air control motor !
BossMach is offline   Reply With Quote
Old 12-07-2011, 03:06 PM   #6
FORDGT14's Avatar
Ok, does this model have a idle screw?
Old 12-07-2011, 03:12 PM   #7
BossMach's Avatar
Not sure,
Old 12-07-2011, 03:42 PM   #8
yes.. it is right by the throttle body.
Old 12-07-2011, 05:46 PM   #9
FORDGT14's Avatar
Is it possible that the computer just needs to re-learn how to idle the new engine? Or re-program?
Old 12-07-2011, 08:57 PM   #10
aegischief's Avatar
As long as the cams are stock, it should be idling normally. The computer wouldn't need to learn anything. Something else is causing the problem.
aegischief is offline   Reply With Quote
Old 12-07-2011, 09:11 PM   #11
Jkgravy's Avatar
Sounds like idle air control and/or throttle position sensor and just to be clear the idle screw isnot the same as the iac.
Jkgravy is offline   Reply With Quote
Old 12-07-2011, 11:21 PM   #12
02PONY's Avatar
My f150 did same thing when I put new engine in it was the maf wasn't hooked up
02PONY is offline   Reply With Quote
Old 12-08-2011, 12:36 AM   #13
FORDGT14's Avatar
Well I wont be able to start it again until i get a new water pump, the one thing i didnt replace went out. Just makes no sense to me
---------- Post added at 02:36 AM ---------- Previous post was at 02:34 AM ----------
Yeah it has stock cams
Old 12-08-2011, 03:52 AM   #14
blackhawk 1's Avatar
murphys law .....
blackhawk 1 is offline   Reply With Quote
10:41 AM
