HP?? - Mustang Evolution
Old 12-09-2011, 03:50 PM   #1
Nashgizam's Avatar
Region: Nebraska
HP??
Alright guys so i have a 02 automatic gt with the following upgrades...... Cold air, 78mm TB, Sct tuner, underdrive pullies, and cat back. how much hp should i be getting now and im thinking about putting in the 4.10s next will i notice much change?
Nashgizam is offline   Reply With Quote
Old 12-09-2011, 05:46 PM   #2
Y2E0L0L5OGWT's Avatar
Re: HP??
I'd have to guess maybe 230 at the wheels.
Gears won't give you any more HP; however, they will result in better acceleration. I don't know what the factory final gearing is on a New Edge, but I am sure it's no where near 4.10's, so you will notice it pull A LOT harder.
Old 12-09-2011, 06:24 PM   #3
shsfresh87's Avatar
Region: West Virgina
With the gears u wont get more hp but it will feel like u did
shsfresh87 is offline   Reply With Quote
Old 12-09-2011, 06:43 PM   #4
Nashgizam's Avatar
Region: Nebraska
Re: HP??
ya i know i wont gain hp from it but i was wonderin how much of a difference it would make
Old 12-09-2011, 06:44 PM   #5
504gt's Avatar
From stock gears it will be a big difference
504gt is offline   Reply With Quote
Old 12-09-2011, 06:47 PM   #6
deadsp0t's Avatar
Stock gears are likely 3.27, will notice a huge change in the cars behavior.
That's unimpressive
Old 12-09-2011, 06:52 PM   #7
Eturner's Avatar
About 260-270hp would be more like it!... I've pretty much the exact same set up!... If you know your 1/4 mile time, speed, and vehicle weight, there is a formula you can use to figure out approximately how much hp your getting ArmyUS wheels!..
I believe 2.73 is the factory gears in a auto!.. So 4.10s will give you a big kick in the butt!...
Old 12-09-2011, 06:56 PM   #8
deadsp0t's Avatar
In 99 I believe they bumped to 3.27 on all of them. If anything the auto would be a little higher.
That's unimpressive
Old 12-09-2011, 07:02 PM   #9
Eturner's Avatar
A higher gear means smaller numbers that represent the gear!.. 2.73 is a higher gear than 3.27!.. If anything the manual would have the 3.27 as that tranny has a fifth gear!..
---------- Post added at 09:02 PM ---------- Previous post was at 09:00 PM ----------
I did a little research some time ago on my car and came up that mine should have 2.73 in the rear!... Mine is a '04 GT auto!...
Old 12-09-2011, 07:03 PM   #10
MMVEC's Avatar
3.27 gears from '99 to '04 came standard on all GT's with manual trans. Not sure about the autos. I can check about autos if you want.
MMVEC is offline   Reply With Quote
Old 12-09-2011, 07:08 PM   #11
deadsp0t's Avatar
Wrong. Before you continue go jack your car up and look at the tag. With Foxes it was 2.73 w/ most 5spd and 3.08 with the auto. In 99' 3.27 became the standard.
Before you start tripping go jack your car up and read the tag on the top right, it will have a series of numbers stamped in it. If you have 2.73's in a new edge GT you'll be the first I know of and would love to see a pic of the tag.
That's unimpressive
Old 12-09-2011, 07:36 PM   #12
Eturner's Avatar
Go for it bro!.. Like I said the research I did said 2.73!... I tried to confirm that with my own diff. and found no tag on it to say one way or the other!.. So if you can find some thing please let me know!.... Lol
---------- Post added at 09:28 PM ---------- Previous post was at 09:13 PM ----------
Mach1registry.com new for 2004 claims the both the V6 and GT auto's had 2.29 in the rear!..
---------- Post added at 09:36 PM ---------- Previous post was at 09:28 PM ----------
Muscle Car drive says 2.29 and 2.49 for the GT!... All sites did say that all manuals have 3.27 in the rear!...
So my question is!..... What the he'll is my final gear!!!..... Lol. Never heard it having a 2.49 before!!!.... Lol
Old 12-09-2011, 09:14 PM   #13
Nashgizam's Avatar
Region: Nebraska
Re: HP??
lol so regardless of my stock gears ill have a monster is wat your telling me correct?? and the 02 gts are supposed to be 260hp stock so shouldnt i be alil more towards 300?? i guess i just dont get that part
Old 12-09-2011, 09:27 PM   #14
Eturner's Avatar
That 260hp stock is at the crank!... What me and the other guy are talking about is hp at the wheels!... With your mods you should be at or above 300hp at the crank!...
Old 12-10-2011, 01:40 AM   #15
Mile high JDF's Avatar
Check the old fashioned way, jack up the rear and rotate the tire once and count how many times the driveshaft spins
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-10-2011, 06:23 AM   #16
deadsp0t's Avatar
+1.. Lol
That's unimpressive
Old 12-10-2011, 06:57 AM   #17
Eturner's Avatar
+1.. Lol
Ya that would be a good idea!.. But I currently don't have a jack!.. Lol. Just ramps!.. Lol
Old 12-10-2011, 07:18 AM   #18
t0t4lbl4ck0ut's Avatar
Lol nash you may be around 300 at the crank. The tuner guy told me I should be putting down around 300-320 at the wheels cammed. But by doing that my power band is larger and it won't fall on its face as much in third
t0t4lbl4ck0ut is offline   Reply With Quote
Old 12-10-2011, 07:21 AM   #19
stampde's Avatar
Re: HP??
I'd guess around 250 / 260 RWHP Range , I know 99-04 's put down about 225/230 stock ..........
2011 GT Auto
Old 12-10-2011, 07:28 AM   #20
Lol now built that Drivetrain as good as you can and you might get an additional 20 to the ground but you'd get piece of mind that if you put slicks on you won't crinkle you driveshaft or snap an axel.
Old 12-10-2011, 07:56 AM   #21
Eturner's Avatar
I e seen that happen a few times and it does suck!!...
Old 12-10-2011, 08:00 AM   #22
That's why I'm not taking any chances. I've been told our 8.8 is tough but I'm not gonna risk my car to a failure lol. I wanna pop wheelies with full on drag slicks and not worry about it. Watch fast intentions video on YouTube. 8.9 1/4 in a 88mm turbo 2v. Pops a 3 ft wheelie lol probably the most beast video I've seen. And people doubt the 2v
Old 12-10-2011, 08:06 AM   #23
Eturner's Avatar
Ya I've got a buddy that has 620+ hp at the wheels with a 91 tune!!... And it's a 2v 4.6!!... Lol. Trust me I don't doubt the potential of our motors!!... Lol
Old 12-10-2011, 08:14 AM   #24
deadsp0t's Avatar
Don't think it's as much doubt as realizing more potential of more valves per cyl. I like the PI motors.
That's unimpressive
Old 12-10-2011, 08:16 AM   #25
I hate it when people just say "do a 4v head swap". If you wanted a 4v you should have just bought a cobra or Mach 1. I personally like the termis but believe they are way overpriced. With an average of 10k more in price you can build a gt up to 500hp and still have left over cash.
Old 12-10-2011, 08:22 AM   #26
deadsp0t's Avatar
I think that's the difference in wanting to build and mod your car to fit you and just wanting to buy one already done up. Sometimes it comes down to money. I will do a swap on mine one day, but it will be a whole new motor not HCI
That's unimpressive
Old 12-10-2011, 08:31 AM   #27
I'm going to put some ported trick flows from mmr on mine. I'm pretty sure that regardless of number of valves, the ported tf will flow better numbers then a stock set of 4v heads. Now ported 4v heads are a different story. All I'm getting at is people abandon and act down on the 2v. Hell my gt beats Mach 1s as it sits with non-degreed untuned cams and bolt ons
Old 12-10-2011, 08:38 AM   #28
deadsp0t's Avatar
Was just reading about those heads! They look to be very promising!
That's unimpressive
Old 12-10-2011, 08:45 AM   #29
Lol yea I'm going with the kenne bell 2.6 kit so the extra flow is perfect lol the standard trick flows will take a bone stock gt from 260 to 380 with just heads and stock cams then you add on the porting and it adds another 45-50 lol AMAZING lol
Old 12-10-2011, 05:40 PM   #30
Cajunick's Avatar
I must know more about this lol any sites with more info on those heads?
Cajunick is offline   Reply With Quote
Old 12-10-2011, 05:46 PM   #31
Well all they are are trick flow twisted wedge heads that mmr ports and polishes to stage 3. I believe they cost around 3100. You can get stage 1-3 too do you don't have to go to outrageous if you don't feel like it
Old 12-10-2011, 06:16 PM   #32
Nashgizam's Avatar
Region: Nebraska
Re: HP??
mmmmm trick flow heads!! website??
Old 12-10-2011, 06:19 PM   #33
Www.modularmustangracing.com
Old 12-12-2011, 03:42 PM   #34
Nashgizam's Avatar
Region: Nebraska
Re: HP??
ok so im thinking to go with a turbo from on3performance.com seems legit
Old 12-13-2011, 06:16 AM   #35
KATO's Avatar
Re: HP??
With adding 4:10 gears, you WILL notice a HUGE difference in the performance of your car, HUGE. My 2007 Mustang GT came with 3:31 gears (verified) and I changed to 4:10, and WOW.
« squeak | IAC Issues »
08:34 AM
