Alarm question - Mustang Evolution
Old 12-09-2011, 04:03 PM   #1
JetLife 01GT's Avatar
Alarm question
I know i posted a different thread earlier but I haven't had my mustang long so I still have many questions lol. Do 01 mustangs come with an alarm? I read in the owners manual that the honk after two clicks is just to tell you the doors are locked. It doesn't say much about an alarm except for the PAT system. I have tried many different ways to trip the alarm and none have worked. I have a sticker in my rear windows that says there is an alarm made by KARR. Is this a company ford had a deal with or is it an aftermarket alarm? I still have and use the original ford key pad. Do you think the previous owner may have put the stickers up just to fool people? Sorry about all the questions guys
Here's a pic of the sticker
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 12-09-2011, 07:23 PM   #2
Burkeys96GT's Avatar
Does your lock/unlock remote have a panic button on it if not hold the lock button for a few seconds if nothing then there isn't a alarm system installed
Burkeys96GT is offline   Reply With Quote
Old 12-09-2011, 07:27 PM   #3
Yeah I have a panic button. But why does the alarm never trip?
2001 GT
Old 12-09-2011, 07:40 PM   #4
MMVEC's Avatar
Roll the windows down. Dbl click the lock button till you hear the horn beep. Open the one of the doors using the inside door handle. Alarm should trip. Did it to mine while detailing the outside with radio on and windows down. Locked doors by accident. When I went to open the alarm went off.
MMVEC is offline   Reply With Quote
Old 12-09-2011, 07:52 PM   #5
I tried that and my alarm did not trip. I even tried leaving it locked for 1 minute after the horn beep to allow for the alarm to set and it still didn't work. Your alarm system is from ford? What year is your mustang?
2001 GT
Old 12-09-2011, 08:44 PM   #6
MMVEC's Avatar
I have a 2000 GT. Bought it new with factory- not dealer-installed alarm.
Old 12-11-2011, 05:40 PM   #7
Cajunick's Avatar
I would check your fuses and if they all check out good check voltage to the alarm horn.
Cajunick is offline   Reply With Quote
Old 12-11-2011, 06:48 PM   #8
Okay. I will try that. Thanks!
2001 GT
Old 12-11-2011, 06:57 PM   #9
99redgt's Avatar
This is kind of off topic but my chip in my spare key is fryed is there anyway to re program the chip?
99redgt is offline   Reply With Quote
Old 12-11-2011, 07:10 PM   #10
Cajunick's Avatar
I'm not sure what you mean when you say fried but if the key lost its coding you may be able to find the procedure online threw a google search. It may look something like start car with your working key insert old key turn ignition on off on off something of that nature. If the procedure you find for your year make and model doesn't work you'll have to goto your local dealer and have try to code it with the ford scan tool if they can't then you will just need a new key..
Old 12-11-2011, 07:14 PM   #11
99redgt's Avatar
Alright I'll try to find it out thanks for the suggestion
Old 12-22-2011, 10:01 AM   #12
Does you alarm system have a sensitivity switch maybe the sensitivity I set to high and it's not detecting a threat mine is so sensitive a Prius can drive by and set it off
Old 12-30-2011, 11:34 PM   #13
94 Mustang GT's Avatar
Only a shop or dealership can reprogram keys with the PATS keys! Have to get access to the computer to learn the new key.
---------- Post added at 12:34 AM ---------- Previous post was at 12:34 AM ----------
The KARR is not factory. I'm not sure what it takes, but I know it's kinda tough to set of the factory alarm.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Exhaust question Codysmustang 1996-2004 Mustang GT 14 11-21-2011 09:11 PM
Kenne bell 2.6L question Ahmed ali khan 1996-2004 Mustang GT 4 11-14-2011 12:54 PM
nitrous question Black99Snake SVT Mustang 4 07-12-2011 09:42 AM
karr alarm system austinknoll General Mustang Discussion 2 07-03-2011 08:16 PM
Aft cat deletion question Mustanglife Pre-2005 V6 Mustang 21 06-27-2011 09:30 AM
06:29 PM
