Upper and lower control arms - Mustang Evolution
Old 12-09-2011, 08:54 PM   #1
CodyNelson's Avatar
Region: West Virgina
I am getting ready to buy a set of HPM Megabite control arms like new for $260. This is a good deal but I was hopin to get some feedback. Has anyone used these or know anyone with them?
Old 12-10-2011, 08:19 AM   #2
CodyNelson's Avatar
Anyone at all?
Old 12-10-2011, 08:28 AM   #3
deadsp0t's Avatar
Was told they hook the hardest, recently read they are not making them any more. Not sure if that's true. The guys I knew with fast DD's all ran mega bites. Though the ride quality wi suffer slightly, that's how you know they work lol as for price I don't know.
That's unimpressive
Old 12-10-2011, 08:31 AM   #4
CodyNelson's Avatar
Okay thanks for the info! This price is great because the run over 500 for the set new and these are like new.
Old 12-10-2011, 08:43 AM   #5
deadsp0t's Avatar
Sweet deal!!
That's unimpressive
Old 12-14-2011, 08:06 AM   #6
CodyNelson's Avatar
Yeah I'm real excited. They should be here by end of the week. Does anyone else know much about them?
Old 12-14-2011, 09:13 AM   #7
onesickstang01's Avatar
Yes they hook very well. Make sure you reinforce torque boxes and everything otherwise you will cause damage. They are hard on the body of the car
onesickstang01 is offline   Reply With Quote
Old 12-14-2011, 10:28 AM   #8
CodyNelson's Avatar
Re: Upper and lower control arms
How do i do that? Subframe connectors?
Old 12-14-2011, 12:06 PM   #9
Subrfrmes and ...
http://www.mikefordmustang.com/write...ll-mustang.php
Old 12-14-2011, 12:23 PM   #10
DaBluedude's Avatar
Yeah I've heard these are really hard. Definitely upgrade the torque boxes... and be ready to learn how to drive with a set of controll arms that feel welded in place... personally I prefer the lakewood or even bbk arms...
2003 Mach 1
Old 12-14-2011, 12:48 PM   #11
deadsp0t's Avatar
You can buy newer boxes and replace the current ones. I've also known ppl to put spot welds around the factory boxes for reinforcement.
That's unimpressive
Old 12-14-2011, 01:02 PM   #12
I did the plates and put huge welds all the way around it all and even another reinforcement plate under the car where the control arm bolts to the torque box. And im only running MM weight jackers on this car
Old 12-14-2011, 01:03 PM   #13
deadsp0t's Avatar
Very nice! I've seen stock boxes rip out of rotted boxes!
That's unimpressive
Old 12-15-2011, 07:48 AM   #14
CodyNelson's Avatar
So would I be better off to see these and get different ones since I rarely go to the track?
Old 12-15-2011, 09:40 AM   #15
If its a DD its a little overkill. They are awesome parts but for streets MM will do just as well, less noise, and better ride/handling. Im actually a fan of BMR as well
Old 12-15-2011, 11:18 AM   #16
DaBluedude's Avatar
Honestly... yes
2003 Mach 1
Old 12-15-2011, 11:39 AM   #17
CodyNelson's Avatar
So should I look into Lakewood? Mm? What would be the best for me? I rarely see the track but I do want something that will hook with the 315s and a v1 t-trim I am in the process of getting
Old 12-15-2011, 11:51 AM   #18
MM or BMR. Steeda has some nice stuff too but expensive and for the price doesnt compare to MM
Old 12-15-2011, 12:17 PM   #19
CodyNelson's Avatar
Okay I'll have to look into them. Do they offer different ones or what should I be looking for?
---------- Post added at 02:17 PM ---------- Previous post was at 02:05 PM ----------
Also, do I need both uppers and lowers? Or will just one or the other work for me?
Old 12-15-2011, 12:21 PM   #20
I run MM weight jackers and love them. MM make several different styles(different bushings) and i think bmr now makes them with urethane bushings and spherical but not 100% sure. Lowers are most important. Uppers not as much but if adjustable they allow you to dial in your pinion angle
Old 12-15-2011, 12:26 PM   #21
CodyNelson's Avatar
But is that something I really need to be concerned with as I'm not trying to cut a quick 60' every weekend?
how would these work?
http://www.uprproducts.com/mustang-9...l-arm-kit.html
Old 12-15-2011, 12:30 PM   #22
Not really. Lower are huge difference
Old 12-15-2011, 12:54 PM   #23
CodyNelson's Avatar
Thanks for your help!
Old 12-16-2011, 04:10 AM   #24
DaBluedude's Avatar
Lakewood+1
2003 Mach 1
Old 12-16-2011, 12:05 PM   #25
CodyNelson's Avatar
I couldnt find much on lakewood, any ideas about where to find there stuff? and also what about these? (no one ever commented when i posted above)
99-04 Mustang Elite Chrome Moly Urethane Control Arm Suspension Kit
Old 12-16-2011, 04:02 PM   #26
DaBluedude's Avatar
I got mine through a local race shop but I could have sworn AM had them... but I dont see them there anymore. They were awesome on my 96, came with preset bushings and if I didn't need to burn out the old bushings iI would have been done in less than 90 mins.
2003 Mach 1
Control arms Travis B 1979-1995 Mustang GT 16 12-07-2011 05:57 PM
Control Arm Interchange fadedsoldier 2011-2014 V6 Mustang 1 11-11-2011 11:35 PM
Bbk u/l control arms Jesse Bach General Mustang Discussion 0 11-08-2011 06:23 PM
04:48 AM
