Unsure of my engine - Mustang Evolution
Old 12-12-2011, 06:54 PM   #1
Nate98stang's Avatar
Unsure of my engine
Ok here are some pics my car is an 02 so it should have the Romeo engine correct? I was told by a buddy I had the 99 engine and I myself am unsure he are some pics if any one could tells I have a short video over looking the engine if anyone wants to pm me a number I could send it to u I just wanna be sure bc if it's my 02 engine then ik the Milage and everything
ID:	35768   Click image for larger version
ID:	35770   Click image for larger version
ID:	35772   Click image for larger version
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 12-12-2011, 08:03 PM   #2
Region: Nevada
Check your head valve covers .. Romeos are 11 bolt Windsor are 13 ..
importkiller is offline   Reply With Quote
Old 12-12-2011, 08:11 PM   #3
I count 11 I think unless I over looked acouple bolts
Old 12-12-2011, 08:23 PM   #4
Region: Nevada
water pump Location is also different post a pick
---------- Post added at 10:23 PM ---------- Previous post was at 10:15 PM ----------
Old 12-12-2011, 08:32 PM   #5
I posted the front of the engine pics up there
Old 12-12-2011, 08:45 PM   #6
You need to pull the numbers off the block.I'm not exactly sure on your motor but most likely on the back somewhere.they are kind of hard to find but you should be able to see them somewhere.that is the best way to tell what you have.
Old 12-12-2011, 09:19 PM   #7
How would b the best way to go about getting them?
Old 12-12-2011, 09:34 PM   #8
Someone else may chime in and tell you exactly where they are located.but I would:
Get some rags,degreaser,small wire brush,mirror, and flash light.
Just start looking around.I think there are numbers on the timing cover but they may not be the same as the one on the block.most of the time they are tricky to find.first pull the numbers off the timing cover and see if it tells the year then search around below the heads,by the bell housing, all over.
But like I said its not hard but hopefully someone chimes in to give u the location so you don't have to search.hope this helps.
Old 12-12-2011, 10:15 PM   #9
Every bit of detail helps thanks u wouldn't b so bad but of Course some parts will only fit the 99-early 01 or the late 01-04 so I need to figure it out for sure
Old 12-13-2011, 05:24 AM   #10
BayyGT's Avatar
Judging by the water pump pulley you have the newer 01-04 engine. And yea those are Romeo. 99-mid 01 were Windsor.
BayyGT is offline   Reply With Quote
Old 12-13-2011, 07:05 AM   #11
onesickstang01's Avatar
You hve a romeo that is 01+. 11 bolt valve covers = romeo. You have the one bolt belt tensioner, short style water pump. Romeo for sure
onesickstang01 is offline   Reply With Quote
Old 12-13-2011, 08:17 AM   #12
Awesome thanks so much guys
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 12:39 AM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
02:03 AM
