281 to 347 swap - Mustang Evolution
Old 12-13-2011, 08:11 AM   #1
Rebbew's Avatar
281 to 347 swap
What would be a better engine to get in to. I have a 1996 mustang gt and I want to get at least 400 hp r better. Here's the problem I don't know what I will have to change r even how much it will cost to do the swap. If its cheaper to just beef up the 281 I will. But a 347 sound a hole lot better. Some one told me the 347 will drop right in because of the year but others say it want. Any suggestions would be greatly appreciated.
Rebbew is offline   Reply With Quote
Old 12-13-2011, 09:40 AM   #2
Burkeys96GT's Avatar
I know someone who swapped I a 460 big block from a older f350. it all depends on you budget
Burkeys96GT is offline   Reply With Quote
Old 12-13-2011, 10:05 AM   #3
02PONY's Avatar
It'd cost about the same to do the 347 swap vs building the 4.6 to 400 hp
02PONY is offline   Reply With Quote
Old 12-13-2011, 10:10 AM   #4
Rebbew's Avatar
That's what I was thinking. Do u know what all I would have to change. I'm thinking k members mounter mounts but what else. I also kinda want to keep the fuel injections so what kind of heads off that. Don't want to spend more than 2000 on heads for sure. So of I had to do carb I would
---------- Post added at 11:10 AM ---------- Previous post was at 11:08 AM ----------
My budget is 4000 max
Old 12-13-2011, 11:07 AM   #5
stampde's Avatar
Re: 281 to 347 swap
dont forget if you change over to the 5.0 engine ,you'll need an engine harness and ECM etc .............. and the agg of wiring in the harness as it wont just be a plug and play
2011 GT Auto
Old 12-13-2011, 11:09 AM   #6
Rebbew's Avatar
Ah... Didn't think of that. So cheaper and easier to go with a carb and manual gauges?
Old 12-13-2011, 11:34 AM   #7
Mile high JDF's Avatar
Why don't you just build the stock 4.6? A trick flow top end kit will run you about 3k and that should get you close to 400bhp. Just do other smaller mods and a dyno tune to get closer to 400whp
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-13-2011, 11:38 AM   #8
Rebbew's Avatar
I'll look into that. Is there a stroker kit for a 281. Maybe like to a 301 r something around that and put that top end kit on it.
Old 12-13-2011, 11:50 AM   #9
Yep there should be plenty of 5.0 stroker kits out there
Old 12-13-2011, 12:00 PM   #10
Rebbew's Avatar
Man I just heard a mustang with that kit on it and holy crap it sounds mean. Screw the 347 swap I'm getting that top end kit. And the stroker kit. Thanks for the help just one more question where can I buy that kit?
Old 12-13-2011, 12:17 PM   #11
Sorry cant help you on that one.
Old 12-13-2011, 12:45 PM   #12
Rebbew's Avatar
U lead me in the right direction and I thank u for it. Have a good one
Old 12-13-2011, 12:49 PM   #13
Welcome. Glad I could help
Old 12-15-2011, 03:23 AM   #14
ColeJohnson's Avatar
Re: 281 to 347 swap
Here's an idea of what you're looking at:
Trick Flow Specialties TFS-K519-390-375 - Trick Flow« Twisted Wedge« Top-End Engine Kits for Ford 4.6L 2V - Overview - SummitRacing.com
2016 Comp Orange GT (current)
5.0 HO swap gc19662007 1979-1995 Mustang GT 16 11-25-2011 08:33 PM
Pi engine swap Kurlywhiteboy 1996-2004 Mustang GT 0 08-14-2011 09:48 PM
Pi engine swap question Kurlywhiteboy General Mustang Discussion 0 08-14-2011 01:56 PM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
2000 3.8 ┬╗ 4.6 swap mustang newb sethhawk1 Pre-2005 V6 Mustang 14 07-28-2011 10:41 PM
11:12 AM
