Differential fluid - Mustang Evolution
Old 12-14-2011, 03:53 PM   #1
Bryangb7's Avatar
Differential fluid
If i have fluid leaking out would it be because the gasket is bad and would replacing the fluid and gasket fix this...also what do you recommend as far as type and brand of dif. Fluid
Bryangb7 is offline   Reply With Quote
Old 12-14-2011, 03:55 PM   #2
If its just the cover it is sealed with RTV silicon. Be sure it's not the pinion seal leaking back to the cover.
FordTech is offline   Reply With Quote
Old 12-14-2011, 04:01 PM   #3
Bryangb7's Avatar
I am having my left rear axle replaced tomorrow (bent) what all does this involve. Would they mess with the differential or is this something I need to do on top of this.
Old 12-14-2011, 04:49 PM   #4
If your having an axle replaced they will need to remove the cover anyways so if it's just the cover leaking it will be fixed as well.
Old 12-14-2011, 05:00 PM   #5
Bryangb7's Avatar
Sweet thank for the info...I'll let him know to check the pinion seal to be safe
Question regards differential Army_Stang 1979-1995 Mustang GT 8 12-08-2011 02:25 AM
Manual Transmission Fluid Napoleon85 2011-2014 Mustang GT 6 11-15-2011 02:47 PM
Best Transmission Fluid Stang23 2005-2010 Mustang GT 0 08-07-2011 12:48 PM
Rear axle fluid Holdempoker102 2005-2010 V6 Mustang 8 07-14-2011 07:56 PM
What Brake Fluid do you use? 99ford General Mustang Discussion 1 06-27-2011 09:34 AM
02:56 AM
