T/B and intake - Mustang Evolution
Old 12-17-2011, 04:54 PM   #1
ridethepony02gt's Avatar
T/B and intake
Ok... I want to upgrade my intake set up. I want to go with the eldelbrock victor Jr. with the bbk 75mm t/b. My question is , is will the bbk work with the intake I want. The reason why I want to use this set up is because bbk makes a plenum and t/b as one. I'm just not sure they'll fit. The guys at AM.com couldn't tell me.
ridethepony02gt is offline   Reply With Quote
Old 12-17-2011, 05:13 PM   #2
deadsp0t's Avatar
Seems like they would, I say that because I would assume both parts should work separately with the stock TB or intake.
Surprised AM didn't know, but summit also has a good customer service too and they may know.
That's unimpressive
Old 12-17-2011, 06:15 PM   #3
Yea they guy at am.com said they probably should. I don't go off probably. I need facts. I was thinking the same thing you were. It should work considering either one would work with stock intake or t/b.
Old 12-17-2011, 06:28 PM   #4
Maybe try contacting one of the manufacturers for peace of mind.
Old 12-17-2011, 07:03 PM   #5
DaBluedude's Avatar
... if both parts are designed to work with stock parts, they should work woth.each other...
2003 Mach 1
Old 12-17-2011, 07:07 PM   #6
Originally Posted by DaBluedude
Why not use the 78mm bbk tb plemum combo?
Your talking about the crackle black one that's a t/b and plenum in one right. That's what I ment. I couldn't remember if it was 75mm or 78mm
---------- Post added at 05:07 PM ---------- Previous post was at 05:06 PM ----------
That's the one I want to use. Not quite sure if it will work with the intake I want to get
Old 12-17-2011, 07:08 PM   #7
Eturner's Avatar
If it's the Victor Jr manifold I'm thinking of then no!.. It will not work because it is made to transition your factory EFI into a Carb. intake!...
Old 12-17-2011, 07:27 PM   #8
93slowstang's Avatar
They make an efi version with bosses for fuel injectors.
Old 12-17-2011, 07:28 PM   #9
deadsp0t's Avatar
http://www.americanmuscle.com/edelbr...ld-9904gt.html
This ones EFI
That's unimpressive
Old 12-17-2011, 07:54 PM   #10
Yea. I know it is. Why did you mention the carb one. That's obvious that it wouldn't work. But yea that's the one with the bbk 78 mm t/b plenum combo
Old 12-17-2011, 08:03 PM   #11
On deadspots link,if you scroll down someone tried using this combo together and didn't work.
Old 12-17-2011, 08:08 PM   #12
Good to know. Thanks for the look out.
Old 12-17-2011, 08:10 PM   #13
No problem.but I'm sure if you really wanted to use it u could custom plumb it .but that begins to be a hassle.
Old 12-17-2011, 08:11 PM   #14
Where you see that. In reviews.
Old 12-17-2011, 08:11 PM   #15
Yeah
Old 12-17-2011, 08:20 PM   #16
I seen it. I'm on my phone and didn't scroll enough. I'd have to buy new fuel rails too and I'm assuming injectors along with comp elbow and t/b. Plus a couple comments below it says no hook up for egr valve. That's not good I live in cali and smog laws are strict. Police pop hoods all the time around here.
---------- Post added at 06:20 PM ---------- Previous post was at 06:17 PM ----------
I don't know why there would be no egr hook up. It would run poorly at idle and cruising speeds with out it. That's when egr is used. Under high vacuum. Hmmm?
Old 12-17-2011, 08:25 PM   #17
Eturner's Avatar
Originally Posted by deadsp0t
Ya that one there looks just like the Carb one!...
Old 12-17-2011, 08:38 PM   #18
onesickstang01's Avatar
It doesnt work. Mmr makes an adapter plate so that it will. You also can only run the edelbrock fuel rails with that intake. Great intake with good numbers though
onesickstang01 is offline   Reply With Quote
Old 12-17-2011, 08:40 PM   #19
deadsp0t's Avatar
+^^ there's your answer!
That's unimpressive
Old 12-17-2011, 08:57 PM   #20
Or you can use the 6061 elbow and any throttle body
Intake Manifold Gasket Mustang1804 1996-2004 Mustang GT 9 11-29-2011 11:11 AM
Cracked Intake manifold... bobsurvives 1996-2004 Mustang GT 7 10-16-2011 01:03 AM
Intake NateNasty 1979-1995 Mustang GT 3 09-23-2011 07:56 PM
Pictures of Intake!!! nickcap 1979-1995 Mustang GT 22 08-04-2011 06:02 PM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 05:55 AM
09:21 AM
