Stock Clutch?! - Mustang Evolution
Old 12-18-2011, 07:34 AM   #1
ColeJohnson's Avatar
Stock Clutch?!
When I bought the car the owner said it had the original clutch. The car was at 99k miles and I called bull but there was no chatter and no slip so I let it slide.
But I'm at 115k miles and the clutch is still perfect?
I know I could find out easily by pulling it apart but I don't have that luxury at the moment.
What are your thoughts?
2016 Comp Orange GT (current)
Old 12-18-2011, 07:43 AM   #2
Las0mbra's Avatar
I'd just let it stay in while it works, you got lucky man!
Old 12-18-2011, 10:28 AM   #3
t0t4lbl4ck0ut's Avatar
Yea I was told that I have a stock clutch in mine and I doubt it cause I've driven several other stangs and my clutch is twice as stiff as any other and it grips with no slip at all. The stiffness is the part I'm curious about. It strange cause I've driven a Stang with a Stage 2 and mines stiffer
t0t4lbl4ck0ut is offline   Reply With Quote
Old 12-18-2011, 10:37 AM   #4
onesickstang01's Avatar
Pull the cover off of the clutch fork area. Look at the pressure plate and compare to factory look. If its silver and rusty its most likely a stock clutch. Most others are painted
onesickstang01 is offline   Reply With Quote
Old 12-18-2011, 11:18 AM   #5
deadsp0t's Avatar
My 1st 95Gt went 125k on stock clutch.
99k with the 1st 2 owners 26k with me
That's unimpressive
Old 12-18-2011, 12:41 PM   #6
Mile high JDF's Avatar
Where along the pedal travel does it engage? If its worn down it should be catching near the top
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-18-2011, 02:55 PM   #7
It's about a 50-75% friction point toward the bottom. And it is still stiff. Lol. Very stiff. Even in comparison to my buddies '88 with a stage 3 clutch.
Old 12-18-2011, 03:43 PM   #8
Is your cable stretched? My friend stretched his out on a king cobra clutch, we put a stock clutch in and it was still stiff. He replaced the cable and it became a lot easier to use
Old 12-19-2011, 04:51 AM   #9
It very well may be the cable. When I clutch in it squeaks.
Old 12-19-2011, 09:39 AM   #10
Ok. Also keep an eye out in your quadrant. Those have been known to snap under heavy clutch feel
Old 12-19-2011, 10:20 AM   #11
mcvicar04's Avatar
I have 190,000 miles on my 04 Gt's stock clutch with no slipping the tob is squeaking a little but still fantastic lol
mcvicar04 is offline   Reply With Quote
Old 12-19-2011, 04:57 PM   #12
Well dang. I was under the impression clutches were more temporary. I guess because I aw my friend blow a clutch every 15k miles in his nismo 350z.. But then again- he really sucked at driving manual. Lol
Old 12-19-2011, 05:13 PM   #13
mcvicar04's Avatar
When a clutch chatters what does that mean?
Old 12-20-2011, 12:17 AM   #14
It just makes some noise kinda sounds like a consistent miss. Like a hiss.
It's just a precursor to it going out, when they get worn a little.
But some chatter for a day then blow, while others chatter forever and don't go out. Mine has been chattering for like six months now but still grips like new.. Lol
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
New guy with a clutch question Cajunick 1996-2004 Mustang GT 7 11-15-2011 11:32 AM
Installing a supercharged 3.8 from a thunderbird SC into my 99 mustang skip318 Pre-2005 V6 Mustang 12 10-01-2011 09:03 PM
Spec or ram clutch 04machazblue 1996-2004 Mustang GT 3 08-23-2011 04:36 PM
09:01 PM
