Routine Maintenance - Mustang Evolution
Old 12-18-2011, 02:39 PM   #1
Zebs5408's Avatar
Routine Maintenance
My GT has ran great up to about 3 months ago, it started hesitating slightly which eventually got worse. I changed the sparks plug and the problem stopped. Then a month after that it started again but even worse, well after inspection of the spark plugs i noticed oil on the tip, i changed the coil pack, The hesitation went away for the most part, but there is still a slight hesitation and im still not getting my power and the response when i punch it is not good at all. What other routine maintenance should i try...I have a fuel filter but have not yet installed it. Im thinking maybe i should try changing all the coil packs but there not cheap..And i would need 7 more.so im hoping its something else. The engine has 150,000 (mainly highway) miles. Ive never had any problems till recently. Thanks in advance guys!
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 12-18-2011, 03:30 PM   #2
pondit0's Avatar
I had the same problem. I changed my plugs and still had a problem. I went to AutoZone and had them hook the Machine up (for free) and it told ne which coil it was. I only had to get one coil. They are way to costly to change all of them at one time. If I had the money to blow I would have changed them all. Personally I'm going to just change them as they go out. Hope this helps.
pondit0 is offline   Reply With Quote
Easy maintenance projects SLDGT500 Shelby Mustang 0 11-25-2011 08:20 PM
Forum Maintenance - Short Downtime Brent ME Site Help & Announcements 1 07-27-2011 04:05 PM
12:29 PM
