Fuel Neck Filler??? - Mustang Evolution
Old 12-19-2011, 03:26 PM   #1
Mustang1804's Avatar
Send a message via AIM to Mustang1804 Send a message via Yahoo to Mustang1804
Fuel Neck Filler???
I have a minor evap leak and when I take sharp turns, I smell a minor odor of gasoline and my service engine soon light is out, can this be the fuel neck filler needs replacing?
Mustang1804 is offline   Reply With Quote
Old 12-19-2011, 07:39 PM   #2
Jack your car up really high on one side to simulate the fuel moving toward the filler neck .then check for leaks.also watch it when you fill with gas.maybe over fill the the tank and watch it also.
Old 12-20-2011, 07:58 PM   #3
I didn't jack it up but I filled it up and took sharp turns and looked in the rare view and I saw small train, after I turned, in the rare view mirror and smelled a minor smell of gas. Is it hard to replace the fuel neck filler?
Old 12-20-2011, 08:16 PM   #4
not sure on your vehicle specificly but usually not.some older cars they are just a hose and hose clamps.
---------- Post added at 09:16 PM ---------- Previous post was at 09:00 PM ----------
I was doing a little surfing and I ran into a thread on another futon that explained: a common problem is the rubber sleave that the tube slides into at the tank.it seems to dry rot out sometimes causing leaks.I think you may have to lower the tank if this is the problem.u may have to just get under there with a flashlight and pinpoint the spot.but here's a link.
http://www.stangnet.com/mustang-foru...ortant.726993/
Old 12-20-2011, 10:08 PM   #5
Wow. Thanks alot, that explains pretty much all I need to know. Once again, thank you very mucn.
Old 12-21-2011, 12:31 AM   #6
Dgibson's Avatar
FML it's 230 am I just read this and went and performed a little test and wouldn't you know my seal is leaking. Looks like the mods are again on hold till I can figure this out on my 98. Ps my engine light was randomly kicking on and off
names doug!
im 21 about to 22. i live in southern indiana. im in the indiana army national guard and i deployed to iraq in 2011.i drive a 1998 gt black and silver. i love playing soft ball,riding four wheelers,crotch rockets and anything to do with cars.
Dgibson is offline   Reply With Quote
Old 12-21-2011, 03:56 AM   #7
No problem!
95 gt fuel issue slow_stang 1979-1995 Mustang GT 22 11-16-2011 05:20 AM
1995 3.8 Mustang Knocking Sound <Transmission> Fuel Injector<AOD????? HELP> Jsan105 Pre-2005 V6 Mustang 2 10-26-2011 07:24 PM
Fuel injectors ?? stangstar92 1996-2004 Mustang GT 3 10-05-2011 04:59 PM
Fuel Filter replacement problem 99 SVT Cobra SVT Mustang 13 07-31-2011 07:25 AM
Serious fuel smell Mustanglife Pre-2005 V6 Mustang 9 07-25-2011 03:18 PM
11:14 PM
